Author Topic: Will This Suspension System Work?  (Read 2399 times)
« on: February 15, 2012, 04:02:56 PM »
Hello everyone,
I am building a track system  that uses the suspension very similar (below) to this on my rescue robot
lego tank suspension
The tread setup I'm using is the image below.  I am using brecoflex timing belts. Length from drive wheel to drive wheel (two top wheels) 25"
My question is Will I need a belt tensioning system or will I be fine without the the tensioning system?
Offline rbtying
  • Helpful? 31
Re: Will This Suspension System Work?
« Reply #1 on: February 15, 2012, 08:14:03 PM »
If you've got belts, you're going to want to use a tensioning system of sort, otherwise the friction of turning will pull them off the idlers (not fun).
« Reply #2 on: February 15, 2012, 10:19:34 PM »
Do you have any ideas on how I coud do this?
Offline [email protected]
« Reply #3 on: February 19, 2012, 10:42:19 PM »
on your diagram, the two black circles are the top pivot points i guess.  one of them is the power wheel and the other just idles i guess.  instead of having the idler be fixed, you could put it on a spring arm so that it continuously pushes out against the track.  i think this is how normal tanks do it.
« Reply #4 on: February 20, 2012, 10:41:18 PM »
Wow! Thanks for the idea!  That's something similar to what I had in mind.
« Reply #5 on: February 21, 2012, 04:37:39 PM »
Do you know where I could find a spring arm like this?
Offline billhowl
  • Helpful? 32
« Reply #7 on: February 22, 2012, 03:09:40 PM »
Do you know how reliable these shocks are?  I read they're made of plastic.  The robot I am building is about 45 in long and weighs about 200 lbs so I am not sure if these are "robust" enough.  Thanks for the suggestion!
What are your guys thoughts on something like this? http://tinyurl.com/7uevvgr
« Last Edit: February 22, 2012, 04:09:29 PM by Mastermime »
« Reply #8 on: February 25, 2012, 05:20:04 AM »
Don't buy expensive "shocks" which are nothing but glorified springs, just find springs of a suitable strength. Leaf springs would be fine as well.
Cheap springs can be found on a junk yard - car seats, beds etc all have either coiled springs or at least steel frames that makes good leaf springs.
I have made several craft knives out of the flat-steel frame from a bed - very good steel quality.
Why are your 'bot so heavy anyway?
« Reply #9 on: February 25, 2012, 11:10:39 AM »
I  just don't want the shocks to go out on me in mid operation.
I'll check at my local surplus store to see what they have.  Unfortunately the closest junkyard is 45 mins away  :-
The batteries weigh 80 lbs and the steel frame weighs about 40 lbs.  then there is about 15 lbs in other things (motors and other things like that)
« Reply #10 on: February 27, 2012, 03:26:49 PM »
All the more reason to get good springs, rather than weak R/C springs.
Good to see your huge enthusiasm ;D
Halving the battery size (if possible) will not halve the run time, but will make it faster and using aluminum or carbon fiber would help a lot too.
« Reply #11 on: February 27, 2012, 05:20:28 PM »
Well fortunately for me the surplus store had an overwhelming amount of options for springs  ;D  So I got 3 different sizes (6 springs total) for only a few dollars.
As I said, I am fairly new to this suspension idea.  How would I attach the spring loaded wheel to the frame?  Would I need some sort of slot to allow it to slide back and forth as the spring compresses and expands?
Unfortunately I have already bought the batteries.
« Reply #12 on: February 28, 2012, 12:42:05 PM »
The easiest way is to mount the (idler) wheel on one end of an arm, with the other end of the arm mounted/hinged on the chassis and the spring pulling the arm away from the belt to tension it.
A roller could be used to push inwards between two wheels on the belt, if that sounds easier.
« Reply #13 on: February 29, 2012, 04:30:44 PM »
Ok I'm having trouble applying that to my design.  Here is a picture of where the spring loaded wheel will go.
The wheel will have to protrude out of the frame because the treads are outside the frame, but the spring system should be inside the frame to prevent it from debris hitting it and what not.
« Reply #14 on: March 03, 2012, 07:19:33 PM »
I recently came across a belt tensioner.  The lightbulb came on. I think I could use something like this http://www.autozone.com/autozone/parts/Duralast-Belt-Tensioner/_/N-apte9?itemIdentifier=421373_0_0_
Do you see any issues of why this may not work?
EDIT: I just went to an auto store and I took a look at one of these and it requires a lot of force to turn one of these.  A little TOO much.  Do you guys know where I could find one of these that would require less force to turn?
« Last Edit: March 05, 2012, 04:29:31 PM by Mastermime »
