Author Topic: remote controlled robots  (Read 855 times)
Offline anigeoTopic starter
« on: March 03, 2012, 07:25:36 AM »
what does it take to convert a line following robot into a remote controlled robot?
I have actually started building one and now realize that i need a remote controlled one for the competition.
Offline Gertlex
  • Helpful? 23
Re: remote controlled robots
« Reply #1 on: March 03, 2012, 12:11:03 PM »
Does the line follower have an MCU? (some do not)
I
« Reply #2 on: March 03, 2012, 08:51:02 PM »
i just read in SOR forums that a remote controlled robot doesn't need a microcontroller.What about this?
Offline Resilient
« Reply #3 on: March 03, 2012, 09:27:31 PM »
This is true. All you need is a transmitter and receiver (http://www.hobbyking.com/hobbyking/store/__9041__Hobby_King_2_4Ghz_6Ch_Tx_Rx_V2_Mode_1_.html) and you are pretty much good to go. You can plug servos directly into the receiver. If you want more powerful motors you can get speed controllers to attach to motors. Either brush-less or brushed. If you want to use differential steering, it gets a little more complicated, but with a nicer computer radio it would be easy enough to set that up. Essentially no programming or soldering required except maybe to connect your motors to you speed controller if you dont buy them with compatible plugs.
Offline Gertlex
  • Helpful? 23
« Reply #4 on: March 04, 2012, 02:33:43 AM »
I asked because I assumed you wanted to use some of the hardware already on your bot, but we have zero idea what this hardware is.
I
Offline gerard
« Reply #5 on: March 08, 2012, 09:34:14 AM »
I have recently made an rc vehicle
all i used was an rc controller/receiver
and a speed control
i put the servos directly to the speed control
i'm using the sabertooth 2x25 two channel motor controller
it works great
Last post August 12, 2007, 04:13:27 PM
by maverick monk
Last post August 11, 2007, 08:05:43 AM
Last post June 26, 2009, 12:26:48 AM
by Soulstoler
Last post July 06, 2012, 09:16:18 PM
by vipulan12
