Author Topic: Cerebellum microcontroller  (Read 8060 times)
Offline roboplane2.0Topic starter
  • Henry the Robot
« on: July 12, 2007, 02:42:55 PM »
can a cerebellum microcontroller control a sharp Ir sensor and 5 servos?
If you're a Halo Fan, click here http://www.freewebs.com/halowireless/forum.htm.
Offline rgcustodio
Re: Cerebellum microcontroller
« Reply #1 on: July 12, 2007, 05:54:13 PM »
From the Botrics website:
    *  On-board dual motor driver circuit to drive two DC motors (up to 2 Amps each).
    * 8 High-Resolution Analog ports.
    * Up to 10 Digital I/O ports.
    * Up to 8 Ports that support Servo hardware.
    * Two user buttons and Two programmable LEDs for debugging.
    * Programming with standard serial port and cable.
    * I2C port allowing daisy chaining of Cerebellums and connection to sophisticated sensors.
this should answer both of your questions.
« Reply #2 on: July 15, 2007, 03:00:54 PM »
My older robots used the cerebellum.
It is no longer sold.
