Author Topic: AVR studio ELF not found  (Read 16911 times)
Offline DothosTopic starter
« on: March 08, 2012, 08:14:38 AM »
I'm getting an error:
Build started 8.3.2012 at 14:04:38
/usr/bin/sh: IC:\MCU\Dev\WebBot\Webbotlib\V1\1.35: command not found
make: [fac2.o] Error 127 (ignored)
mmcu=atmega640  fac2.o   -L"C:\MCU\Dev\WebBot\Webbotlib\V1\1.35"  -lWebbot-ATmega640 -lm -lc  -o fac2.elf
/usr/bin/sh: fac2.o: command not found
make: [fac2.elf] Error 127 (ignored)
avr-objcopy -O ihex -R .eeprom -R .fuse -R .lock -R .signature  fac2.elf fac2.hex
avr-objcopy: 'fac2.elf': No such file
make: *** [fac2.hex] Error 1
Build failed with 1 errors and 0 warnings...
I dont know what to do. It happens when try to not use the makefile created by the project designer so I can add another lib folder.
I need some help please.
Thanks in advance
Re: AVR studio ELF not found
« Reply #1 on: March 09, 2012, 09:23:20 AM »
You are using a very old version of WebbotLib . . . download the latest 2.0x version and compile for that using the latest libraries.
« Reply #2 on: March 10, 2012, 02:41:34 AM »
Ok, I'll do that. but in my main pc I do it like this and it works fine. Are you sure that's the problem?
Offline joe61
« Reply #3 on: March 10, 2012, 06:20:30 AM »
This looks like a directory, not a command, which makes me think something was left out of the makefile.
I'm guessing this happened because the command needed to build fac2.o was missing (first error).
I'd have to guess too much for a useful answer, can you post the makefile?
Joe
Offline mstacho
  • Helpful? 10
« Reply #4 on: March 10, 2012, 10:07:05 AM »
Hm, I have been having this problem as well.  It happened when I tried to install AVRStudio 4, whichever is the latest version 4 but NOT version 5 (man, did I EVER screw up explaining that one :-P ) over Windows 7.  I installed AVRStudio 5 and it works like a charm.
I have no idea why it can't find the *.elf file, though, but it is apparently something to do with the makefile that's been generated.
Upside: AVRStudio 5 works swimmingly with Windows 7 and Webbotlib, although I'm using an ISP programmer rather than a bootloader.
MIKE
« Reply #5 on: March 13, 2012, 07:38:59 AM »
About the makefile. I create the code using Project Designer then I open with AVR 4 and then I uncheck the use external makefile so I can add the folder where I have my own lib... And only when I do that I get the error but I did it in my home computer and it works fine but I can't seem to do it anywhere else. What could be wrong? I tried with the version 2 of the lib and I got the same error..
# Makefile for the project fac2
## General Flags
PROJECT = fac2
MCU = atmega640
TARGET = fac2.elf
CC =
CPP = avr-g++
## Options common to compile, link and assembly rules
COMMON = -mmcu=$(MCU)
## Compile options common for all C compilation units.
CFLAGS = $(COMMON)
CFLAGS += -Wall -gdwarf-2 -std=gnu99      -DF_CPU=16000000UL -O0 -funsigned-char -funsigned-bitfields -fpack-struct -fshort-enums
CFLAGS += -MD -MP -MT $(*F).o -MF dep/$(@F).d
## Assembly specific flags
ASMFLAGS = $(COMMON)
ASMFLAGS += $(CFLAGS)
ASMFLAGS += -x assembler-with-cpp -Wa,-gdwarf2
## Linker flags
LDFLAGS = $(COMMON)
LDFLAGS +=  -Wl,-Map=fac2.map
## Intel Hex file production flags
HEX_FLASH_FLAGS = -R .eeprom -R .fuse -R .lock -R .signature
HEX_EEPROM_FLAGS = -j .eeprom
HEX_EEPROM_FLAGS += --set-section-flags=.eeprom="alloc,load"
HEX_EEPROM_FLAGS += --change-section-lma .eeprom=0 --no-change-warnings
## Include Directories
INCLUDES = -I"C:\MCU\Dev\Axon2_projects\factory_2\..\..\WebBot\WebbotLib\V2\2.08" -I"C:\MCU\Dev\Axon2_projects\factory_2\..\..\dothoslib"
## Library Directories
LIBDIRS = -L"C:\MCU\Dev\WebBot\WebbotLib\V2\2.08" -L"C:\MCU\Dev\dothoslib"
## Libraries
LIBS = -lWebbot-ATmega640 -lm -lc
## Objects that must be built in order to link
OBJECTS = gen_tone.o opt_TimerCompare.o opt_DeviceName.o fac2.o opt_TimerCapture.o lib_timerdef.o lib_timers.o lib_iopins.o opt_pcint.o opt_TimerOverflow.o gen_clock.o opt_scheduler.o lib_hardware.o
## Objects explicitly added by the user
LINKONLYOBJECTS =
## Build
all: $(TARGET) fac2.hex fac2.eep fac2.lss## Compile
gen_tone.o: ../lib/gen_tone.c
$(CC) $(INCLUDES) $(CFLAGS) -c -Os $<
opt_TimerCompare.o: ../lib/opt_TimerCompare.c
opt_DeviceName.o: ../lib/opt_DeviceName.c
fac2.o: ../fac2.c
$(CC) $(INCLUDES) $(CFLAGS) -c  $<
opt_TimerCapture.o: ../lib/opt_TimerCapture.c
lib_timerdef.o: ../lib/lib_timerdef.c
lib_timers.o: ../lib/lib_timers.c
lib_iopins.o: ../lib/lib_iopins.c
opt_pcint.o: ../lib/opt_pcint.c
opt_TimerOverflow.o: ../lib/opt_TimerOverflow.c
gen_clock.o: ../lib/gen_clock.c
opt_scheduler.o: ../lib/opt_scheduler.c
lib_hardware.o: ../lib/lib_hardware.c
##Link
$(TARGET): $(OBJECTS)
$(CC) $(LDFLAGS) $(OBJECTS) $(LINKONLYOBJECTS) $(LIBDIRS) $(LIBS) -o $(TARGET)
%.hex: $(TARGET)
avr-objcopy -O ihex $(HEX_FLASH_FLAGS)  $< $@
%.eep: $(TARGET)
-avr-objcopy $(HEX_EEPROM_FLAGS) -O ihex $< $@ || exit 0
%.lss: $(TARGET)
avr-objdump -h -S $< > $@
## Clean target
.PHONY: clean
clean:
-rm -rf $(OBJECTS) fac2.elf dep/* fac2.hex fac2.eep fac2.lss fac2.map
## Other dependencies
-include $(shell mkdir dep 2>NUL) $(wildcard dep/*)
Many thanks for your help anyway.
Offline joe61
« Reply #6 on: March 13, 2012, 10:53:23 AM »
Are you sure you're using the same makefile on both computers? The error message you gave at first doesn't appear to match this makefile.
I don't have time to look at this carefully, but it doesn't look like the makefile that generated the errors.
Joe
« Reply #7 on: March 13, 2012, 01:40:56 PM »
WWhat I just did in both computers was to disable the use external makefile so I can add another include directory to use my own lib.
Can someone just tell me then what I need to change in the makefile generated by the Project Designer to include another dir? Or what would be the best approach to solve this problem... I'm in kind of a hurry because I've got a robotics competition and I can only compile the code in my home computer  :-\
« Reply #8 on: March 13, 2012, 09:24:32 PM »
Dothos, you can add additional directories right in Project Designer . . .
go to Tools -> Generate, and then in the new window click Add at the bottom to add include folders.
« Reply #9 on: March 15, 2012, 02:49:17 PM »
LOL I feel so noob I don't know how I missed that but many thanks for taking time for such things.
It solved my problem ;)
