Author Topic: programming $50 robot w/ Mac  (Read 490 times)
Offline andymacTopic starter
« on: March 09, 2012, 05:15:42 PM »
Has anyone had any luck with programming the $50 robot with a Mac?  Or better yet, using the Ardiuno IDE?
AndyMac
Offline joe61
Re: programming $50 robot w/ Mac
« Reply #1 on: March 09, 2012, 06:26:37 PM »
avrdude is software used to drive a hardware programmer. It was originally written to run on FreeBSD (which is where OS X came from). So it should work fine with the programmer suggested by the tutorial.
See here for some setup instructions.
The arduino ide is probably a non-starter unless you want to port it to the Atmega8. Or you could use an Atmega 328, with some of the same components as the arduino, but then you're not building the $50 robot anymore :-)
Joe
Last post June 27, 2007, 07:35:09 PM
Last post July 31, 2009, 11:56:47 PM
by apc3161
Last post March 28, 2011, 06:26:59 AM
by junkman
Last post December 06, 2011, 04:36:12 PM
by newInRobotics
