Author Topic: ROPE CLIMBING ROBOT  (Read 2345 times)
Offline masaoTopic starter
ROPE CLIMBING ROBOT
« on: March 14, 2012, 06:57:29 AM »
HOW TO BUILD A SIMPLE ROPE CLIMBING ROBOT WHICH IS PURELY MECHANICAL WHICH WILL BE TRIGERRED BY A LOAD? AND THE ROBOT WILL STAY AT ONE POINT OF THE ROPE. PLEASE HELP ME
Offline jkerns
  • Helpful? 10
Re: ROPE CLIMBING ROBOT
« Reply #1 on: March 14, 2012, 04:38:24 PM »
Climb how? Using arms grasping and releasing the rope? Running the rope between some wheels that pinch it and allow it to climb? Winding the rope around a drum?
http://www.ltu.edu/engineering/mechanical/robotics_engineering.asp
« Reply #2 on: March 15, 2012, 07:26:30 AM »
the rope will be fixed but the robot must climb the rope no matter how. batteries are not allowed to make the robot climbing as it should be purely mechanical
Offline newInRobotics
  • Helpful? 45
  • N.I.R.
« Reply #3 on: March 15, 2012, 07:33:29 AM »
Use two rollers (pulleys) spun by wind up mechanism.
« Reply #4 on: March 15, 2012, 02:14:02 PM »
how to  make sure that the robot will move when a load is place on the robot by wind up mechanism? the load is a tennis ball.
  • Helpful? 45
  • N.I.R.
« Reply #5 on: March 15, 2012, 03:17:31 PM »
Just pick wind up mechanism that is strong enough. If You have torque meter - You can measure how much torque wind up spring can output and compare it against torque required to lift assembly up the rope. If You don't have access to torque meter, than trial and error is the way to go.
Offline jkerns
  • Helpful? 10
« Reply #6 on: March 15, 2012, 03:29:29 PM »
How is the load put in place? Can it be set on a lever (platform) that will unlock the windup mechanism?
« Reply #7 on: March 15, 2012, 04:46:47 PM »
Make a lever that latches to the rope (blocking any climbing motion) until the ball is put on it - that way it will stay in place by the wind-up pushing upward against the latch.
« Reply #8 on: April 12, 2012, 10:56:32 PM »
How to unlock the wind up mechanism?
Offline jkerns
  • Helpful? 10
« Reply #9 on: April 13, 2012, 07:12:56 AM »
You have some kind of wind up clockwork, right?
It is going to have some kind of gears or wheels - you can put a notch in one of these, and make a lever that fits into the notch and stops rotation. On the other end of the lever is a place to put your load. The load will "tip" the lever a little and pop it out of the notch.
Eh?
Last post August 06, 2007, 11:21:10 AM
by alpha_geek
Last post December 10, 2008, 03:58:09 AM
Last post August 29, 2009, 05:28:56 PM
by Joker94
Last post October 07, 2011, 09:44:48 AM
by Conscripted
