Author Topic: 4 wheels vs 3 wheels  (Read 1392 times)
Offline alucardTopic starter
« on: March 14, 2012, 03:58:51 PM »
Hi all,
I am designing a high speed line-following robot, which needs to turn quite often using differential drive.
Can anyone enlighten me the advantages and disadvantages of using 3 wheels (2 back driven wheels + 1 front wheel) vs 4 wheels (2 back & 2 front) ?
Thanks!
Offline jkerns
  • Helpful? 10
Re: 4 wheels vs 3 wheels
« Reply #1 on: March 14, 2012, 04:36:08 PM »
4 wheels - skid steering by differential powering of both front and back or 2 driven wheels and 2 castors?
4 wheels will make it less likely to tip over than 3. Skid steering will be less responsive and waste some of your battery energy compared to using casters.
http://www.ltu.edu/engineering/mechanical/robotics_engineering.asp
« Reply #2 on: March 14, 2012, 04:45:35 PM »
In both the 3-wheel and 4-wheel cases, the back 2 wheels are motor-driven. The front wheels are rigid castors wheels (they can rotate freely but not turn sideways)
I think for 3 wheels, it shouldn't be easy to tip over , if the robot is wide and has low centre of gravity.
I cannot use a ball castor because the robot must be able to travel on concrete pavement (with small cracks)
Are you saying I should go for  3 wheels since less skid steering (friction)?
« Reply #3 on: March 14, 2012, 06:25:37 PM »
If each front wheel is mounted on a separate (good quality) castor, it won't make much difference with 3 or 4.
However... Did you consider the driven wheels at the approximate center, with a single castor at each end?
That would keep the majority of the weight on, or close to, the driven wheels (thus it takes less power to turn) and the smaller (I assume) castor wheels won't dig into holes as easy, as it doesn't carry much load, just supporting the unit from tipping over.
Offline jkerns
  • Helpful? 10
« Reply #4 on: March 14, 2012, 07:59:57 PM »
So you plan to have the front wheels mounted so they can't turn (like this:  http://www.harborfreight.com/8-inch-cushion-tire-fixed-caster-46817.html and not like this: http://www.harborfreight.com/8-inch-cushion-tire-swivel-caster-46818.html ) to line up with the direction the robot is turning?  So you have to skid the wheels sideways to turn?
I would think that will not help the steering because you will have a mix of skidding the front wheels and slipping the drive wheels.
If you get reasonably large diameter castering (swiveling) wheels, they should roll OK even on pavement.
« Reply #5 on: March 14, 2012, 08:08:43 PM »
I am afraid that swivel wheels would get stuck at cracks in the concrete. For e.g., one part of the ground could be slightly higher, and if the wheel 'bangs' flat against the higher part, then it might get stuck
How about using an omni-wheel like http://dl.dropbox.com/u/17243832/omni.PNG
« Reply #6 on: March 15, 2012, 04:53:44 PM »
Omni or not, any wheel that meets a vertical obstacle higher than or equal to the radius of the wheel will be a dead stop.
Offline gerard
« Reply #7 on: March 16, 2012, 05:55:19 PM »
true ^^^^
but not if it's powered
having 3 or 4 wheel drive would solve that problem, but i don't think that's necessary just for cracks
and cracks aren't anything a wheel can't deal with unless the cracks are wide
Offline Gertlex
  • Helpful? 23
« Reply #8 on: March 21, 2012, 12:55:12 PM »
true ^^^^
but not if it's going fast. Then it's an exciting crash :)
I
Last post March 14, 2007, 05:06:54 PM
by Brandon121233
Last post December 29, 2007, 10:08:57 PM
by ed1380
Last post August 10, 2008, 07:19:07 PM
Last post July 31, 2009, 11:27:24 AM
by wil.hamilton
