Author Topic: Control shutter door from PC  (Read 804 times)
Offline EpachkTopic starter
« on: March 16, 2012, 08:32:22 AM »
Hi, I´m new to the forum
I have a question maybe you can solve:
I´m installing two security roller shutter doors in my house 4.5 mt (14.7637 ') width x 2.5 mt (8.20209 ') in hight.
They both operate on individual electrical engines. I dont have much info about the engines (I can ask the manufacturer), so far I know they work at 35 rpm. I dont know how much they consume, but you can guess they are quite potent (I mean, they are not toy engines but not industrial engines either).
They are operated manually (I mean up and down buttons)
I was wondering: is there a way to connect these engines to a normal PC under Windows so I can open and close the shutter doors from my computer? Without overriding the normal manual operation.
I know I have to develop a software (maybe there is something I can buy that is already programmed), but how about the electronics involved? how can I connect the engines to a PC?
I´m an advanced architect student but I dont know much about automation. Im looking fordward to learn more, I believe this is a good project to start.
Thanks for your time guys and sorry for my english (native lenguage is spanish).
Offline joe61
Re: Control shutter door from PC
« Reply #1 on: March 16, 2012, 08:48:40 AM »
Maybe something like an X10 or INSTEON module would work. I don't know about this application but in general they use the electrical wiring in the house as a network, so you can communicate with many modules doing different things. Take a look at http://www.smarthome.com/_/index.aspx
There are lots of on/off type things you can plug a lamp into, there might be something similar for your application.
Joe
Offline newInRobotics
  • Helpful? 45
  • N.I.R.
« Reply #2 on: March 16, 2012, 08:59:15 AM »
Hi and welcome :)
To control high power motor (ON/OFF only, no speed control) I'd use a relay, which in turn is driven by transistor, which in turn is driven by microcontroller, which acts as a bridge between PC and a motor. A bit long sentence  ;D
PC --> Microcontroller --> Transistor --> Relay --> Motor
If it's DC motor (as opposed to AC motor) then relay can be skipped.
Communication between PC and Microcontroller can be achieved in different ways:
1. USART wired communication (USB or Serial port from PC to TX/RX pins of microcontroller).
2. Bluetooth
3. WiFi
4. RC (like in remote control toys)
I know I have to develop a software [...]
Software (PC side and microcontroller side) is not difficult (although I don't know how much You know about programing) for USART (wired) communication. For wireless type - I don't know as I've never attempted to implement one.
« Reply #3 on: March 16, 2012, 09:24:43 AM »
Thank you for the reply.
Im not a programmer, I do have some programming knowledge buy most of my close friends are programmers, so I can solve that.
I dont need this to be wireless, Im doing some remodelling on my home and Im wireing everything (inside wall wiring).
newInRobotics, I dont need to control speed, but can I control how much the shutter door opens or closes? say, 25% 50% 75% and so on. Not only full open or full close.
Does that involve a different hardware or is just programming?
Ill investigate on the components you mentioned. Thank you very much.
  • Helpful? 45
  • N.I.R.
« Reply #4 on: March 16, 2012, 11:32:00 AM »
You also need someone able to program microcontroller, as that is quite different from programming Windows.
That might be a problem as if PC is far away from microcontroller serial wired communication might fail, although I'm not sure what the maximum distance is; I'll leave that for You to find out.
Yes, shutter position can be controlled easily using relays (very rough circuit is attached below). The only problem might be knowing how much open/closed shutter is. If You have some sort of CCTV system which gives You view of shutter gate, then that is all fine, however, if You can't see the shutter - some sort of sensors has to be used (rotary/linear encoder for example).
« Reply #5 on: March 16, 2012, 09:38:40 PM »
[...] I dont have much info about the engines (I can ask the manufacturer),
Please do, or see if there's a label on each motor telling the voltage (V) and current (A) they need and whether they're AC or DC.
The control depends on this info.
Where there's a will, there's a way :)
Actually, the manual controls will just be extra inputs to a power controller, for overriding the automatic control.
There's a number of possible ready made solutions on the software side - try some of what's mentioned here
At the electronics side of things, you can split it up in 3 sections:
PC interface, transmission medium and power control.
For the PC interface, you have to look at what ports are on your PC - parallel, serial, USB or...
If it's a current PC, USB is the likely candidate and you can get a cheap USB control interface with eg. 8 lines in/out or something much larger - it depends on your budget and if you want to prepare for future automation projects.
The transmission medium can be a simple wire, comms over the mains or radio (like X-10 or Z-Wave).
The power control depends on the motors you have. If they're AC mains, a TRIAC control will be the cheap and cheerful solution, with DC, a relay will probably be the easiest for you - but we need the info on the motors to advice properly.
You can either make them fairly "dumb" or use a microcontroller at each power unit - it depends on the level of automation you shoot for and whether you'd like things to run smoothly even if the PC acts up.
To have various positions between fully open an fully closed, you can use optical detection if only a few positions are needed and the PC could just issue a command like "open 50%", and the power driver would then start and keep on until the 50% open is detected.
For data/control integrity, it would be proper to let the power module return a "job done" message when it reaches the point and the software could then be made to alert you if it didn't within a given time frame.
What's an "advanced architect"?
(I get a mind image of weird structures here ;))
Don't worry, your English is very readable, only the term should be "motor", rather than "engine", but we get it anyway :)
Do add 2..3 cat-5 or cat-6 cables, a few extra mains cables, perhaps a heavy gauge cable for 12V or 24V distribution and maybe one or two 75 Ohm coax (assert your needs for extending the home control concept - once you start, you get ideas of automating lots of trivial tasks around the house), make sure that you're set for some time onwards.
A close friend rewired completely and installed only a single cat-5 for control purposes and he quickly ran out of wires, so I had to make him a mux unit to get a lot more down the few wires and we're planning a wireless interface for all his lamp dimmers, the heating and some parts of his access control - you can never have too many wires, copper is better (and cheaper) than other transmission media ;D
Of course, but what granularity do you really want/need?
The quarter increments you mention is best solved by either infrared detectors or inductive proximity switches - mechanical switches will be too unreliable and wear down.
If you need fine control over the position, there are several options, but it will be less reliable than a few hard wired positions and I'd think that the most useable would be: small opening (for ventilation), ~30..50% open for serious ventilation and 100% open would cover most needs.
I probably don't need to tell an (advanced) architect student that it's a very good idea to sketch out your plans and adjust and adapt over some days or more, but Just in case... :)
Last post April 24, 2007, 06:16:14 PM
Last post March 01, 2009, 04:54:20 PM
by Razor Concepts
Last post September 16, 2010, 07:31:36 AM
by waltr
Last post October 30, 2011, 10:53:39 AM
