Author Topic: Scanning Sharp IR Servo Recommendations  (Read 2042 times)
Offline silo_xtremeTopic starter
  • I really love robots, they keep me awake at night.
« on: July 13, 2007, 08:49:51 AM »
Hi Roboticists,
What servo would you reccomend to use with the Sharp IR Sensor for 180 degrees?  I know the HS-311 is popular for the $50 robot, but if you had to do it again - would you make the same decision?  What servo does hyper squirrel use?  :)
Offline KambeiX
Re: Scanning Sharp IR Servo Recommendations
« Reply #1 on: July 13, 2007, 09:31:13 AM »
hs-311 is a very good choice for that application.
You may use a smaller one since you don't need force, but there aren't many cheap micro servos with 180°
« Reply #2 on: July 13, 2007, 09:43:42 AM »
What about pan and tilt systems?  Perhaps something like this one http://www.servocity.com/html/spt100_pan___tilt_system.html ?
« Reply #3 on: July 17, 2007, 07:32:42 PM »
Well I use the HS-311 on hypersquirrel cause its cheap and I have tons of them.
Ideally you want one with a really high rotation speed (torque doesnt matter). Bigger servos are slower when changing direction (higher momentum), so you probably want small servers with high speed ratings.
Last post July 13, 2007, 11:13:55 AM
Last post June 15, 2010, 03:58:25 PM
by gary_ramsgate
Last post April 21, 2011, 07:02:20 AM
by joe61
Last post July 21, 2012, 03:57:21 PM
by spooneythegoon
