Author Topic: Using Arduino Uno for the 50$ robot  (Read 1394 times)
Offline vitalik53Topic starter
« on: March 23, 2012, 06:21:02 PM »
Hey guys,
i I was just wondering if its possible to use Arduino uno to implement the 50$ Robot with SHARP IR sensors, is there any Arduino functions that would replace the ATMega8 code Admin wrote
in separate files.  Also, how would you send a specific pulse to a servo, would you use the digitalWrite and the delay command? Thank you
Re: Using Arduino Uno for the 50$ robot
« Reply #1 on: March 23, 2012, 06:46:22 PM »
It is.
in separate files.
Just make a program to do the same thing. I'm sure you can find plenty of examples at either Arduino.cc or the Arduino code repository.
There's plenty of servo libraries fr the Arduino. Get one of them an read the documentation.
Offline billhowl
  • Helpful? 32
« Reply #2 on: March 23, 2012, 10:57:55 PM »
in separate files.
Here is the code that can just copy into arduino IDE
http://www.societyofrobots.com/robotforum/index.php?topic=7759.msg59798#msg59798
« Reply #3 on: March 23, 2012, 11:51:53 PM »
i understand how it works using the Servo.h library, but i need to convert 'Admin's' code for the SHARP IR rangefinder $50 robot, not the photoresistor $50 robot, into arduino. Also, if you have done the project using sharp ir, can you explain please what the scan_angle values 30 to 57 represent, and where does 'scan_angle>41' comes in ??? thank you
