Author Topic: Linear actuator  (Read 626 times)
Offline bakerTopic starter
Linear actuator
« on: March 30, 2012, 02:40:21 AM »
Hi guys,
I'm planning to make a robot that uses a linear actuator to lift it 1 meter vertically, I saw some actuators on the net but they are so expensive (more than 200$ !!). However, I saw some projects that used similar mechanism but horizontally not vertically. Any ideas on how to modify them?? Watch this video for more details:
Robot
Re: Linear actuator
« Reply #1 on: March 30, 2012, 09:47:35 AM »
Just turn it 90°? ;)
You have to plan out your project a little before asking all your questions. Make drawings, calculate power needed etc.
The horizontal movement in the video is more or less the mechanics from a scanner or printer, Find one in a dumpster and strip it for parts (motor, axles, gears/timing belts etc.) and use the parts for your 'bot.
You keep on with the 1m height, but you don't say anything on how high it is allowed to be when retracted.
Plan, plan, plan - use plenty of pencil and paper and don't be afraid to wear down a couple of math calculators - that will make some of the answers obvious :)
When you come back with questions that stems from a planned out robot, it will be easier to help you and as long as you just ask about stuff that you only loosely imagined, your answers will, at best, be only loosely applicable.
Last post February 06, 2013, 11:59:21 AM
by Mr.Actuator
Last post April 26, 2012, 02:07:52 PM
by Robot Attack
Last post June 06, 2012, 07:02:35 AM
by jkerns
Last post August 03, 2012, 08:36:12 AM
