Author Topic: servos for the 50$ robot  (Read 843 times)
Offline monsieurp0Topic starter
« on: April 10, 2012, 07:30:09 PM »
hi everyone im new and im planning to build the 50$robots probably with the ir but i dont feel confortable to modify the servo can i buy already modified servos?where?
Offline Gertlex
  • Helpful? 23
Re: servos for the 50$ robot
« Reply #1 on: April 10, 2012, 08:53:26 PM »
Here's one example. It quadruple the price, though: http://www.servocity.com/html/hs-311_standard.html
At that point you might as well buy extras if you really think you're going to mess some up :)
I
Offline beachboy612
« Reply #2 on: June 29, 2012, 12:31:36 PM »
it really isnt that hard.  all you need is crazy glue, a small screwdriver sharp knife, and tweezers.  take gears out w/ tweezer so they arent contaminated and place them on a clean surface.  then saw the pot off using the scissors.  make sure there are no burs as to not interrupt the gears when they are spinning.  send the signal through the microcontroller to the servo.  use tweezers to turn pot until gear stops.  crazy glue it in place, then put servo back together.  very simple.
Last post August 12, 2006, 04:39:20 PM
Last post September 29, 2007, 04:42:12 PM
Last post December 03, 2007, 02:41:39 PM
by SciOlyStudent
Last post March 01, 2008, 06:21:26 PM
by airman00
