Author Topic: Webbotlib Serial Servo Driver Problem  (Read 490 times)
Offline GertlexTopic starter
  • Helpful? 23
« on: April 17, 2012, 06:13:53 PM »
In Project Designer, the Serial Servo Driver lets you specify servos, but it gives no indication of what position on a serial servo driver the servo should be located at.  8 servos are supported by both the original MiniSSC II board and the Pololu Micro Serial Servo Controller (both of which can use the Mini SSC protocol), though I know other boards have other numbers.
Am I missing something, or are these an incomplete implementation?
(Unrelatedly, I *have* controlled the Mini SSC II with hand code on the Axon in the past, but I have been completely unable to get the Pololu SSC to respond to output from the Axon.)
I
  • Helpful? 107
Re: Webbotlib Serial Servo Driver Problem
« Reply #1 on: April 17, 2012, 07:59:28 PM »
Am not quite sure I understand what you are asking? Is it: 'Why doesnt Project Designer show you how to connect the servos to the board?' .
If so then: it can't. The MiniSSCV and Pololu protocols that it allows you to choose from are just software protocols supported by a number of different hardware boards but which all work the same. PD doesn't know which one you are using.
  • Helpful? 23
« Reply #2 on: April 17, 2012, 10:45:11 PM »
Not quite what I was getting at, sorry.  For example, the Mini SSC protocol's 3 byte packets include a servo number.  How do I tell project designer which number corresponds with a servo that I "add" to the Serial Servo Driver?
Thanks!
I
  • Helpful? 107
« Reply #3 on: April 18, 2012, 06:22:32 PM »
Its dictated by the order you add them to the list in Project Designer.
Last post September 24, 2008, 07:56:37 PM
by Ro-Bot-X
Last post May 06, 2010, 08:57:51 AM
by Webbot
Last post July 05, 2010, 01:36:04 PM
by digital_pants
Last post September 20, 2011, 07:44:56 AM
by Gertlex
