Author Topic: How does dividing 1 Nm over a small wheel work?  (Read 700 times)
Offline EithmanTopic starter
« on: May 03, 2012, 07:48:24 PM »
I found a servo that provides a little over 1 Nm of torque. Since a Nm = 0.74 Foot pounds, if I applied 1 Nm to a wheel that had a 10cm circumference, 100cm/10cm = 10,  And changed foot pounds to meter pounds .74 FP * .305 = .226 would each rotation of the 10cm wheel be pulling with 2.26  lbs of force? .226 * 10 = 2.26 lbs? Disregarding efficiency. Is this correct, if so could you explain where I went wrong?
Offline jkerns
  • Helpful? 10
Re: How does dividing 1 Nm over a small wheel work?
« Reply #1 on: May 03, 2012, 08:37:08 PM »
Torque = force * distance
Force = Torque / Distance.
The distance is the radius of the wheel, not the circumference. You use the circumference to convert revolutions to distance traveled, but think of torque as a force applied to a lever with a length that is the radius of the wheel.
http://www.ltu.edu/engineering/mechanical/robotics_engineering.asp
« Reply #2 on: May 03, 2012, 10:10:36 PM »
Ok, so if the radius of the wheel was 10 cm and everything else was the same, would the answer be the same as before?
Offline jkerns
  • Helpful? 10
« Reply #3 on: May 04, 2012, 09:35:54 AM »
10 cm radius = .33 feet.  (20 cm diameter)
.74 ft-lb / .33 ft = 2.2 pounds of tractive force.
Same answer.
« Last Edit: May 04, 2012, 09:38:00 AM by jkerns »
« Reply #4 on: May 04, 2012, 10:40:24 AM »
Excellent! Thank you very much!
Last post February 14, 2007, 11:21:47 AM
by annoyin_kid
Last post November 12, 2008, 05:31:21 PM
by Commanderbob
Last post December 09, 2008, 08:11:21 AM
Last post February 04, 2009, 11:14:40 PM
by darwa
