Author Topic: suitable battery pack for Axon II  (Read 388 times)
Offline aaa3aTopic starter
« on: May 07, 2012, 07:06:19 AM »
i am a new to axon and need to know what is the suitable battery pack to work with Axon II no dc motors just voice recognition module and sonar sensor the dc and servo motors supplied by separate battery pack
i have 2 battery pack one with specs.
                                               6 volt 4Ah
                                  initial current less than 1.20A
                                  cycle      use  :7.20-7.50 volt
                                  standby use  :6.75-6.90 volt
and the other is 5 cells 1.2volt 2200mAh connected in series to give around 6 volt
can i use the first one with Axon II or should i use the second
what is the maximum volt and amp for Axon II
Offline Gertlex
  • Helpful? 23
Re: suitable battery pack for Axon II
« Reply #1 on: May 07, 2012, 08:29:55 AM »
Maximum voltage.
The way you ask the question in the last part of your line, I suspect you don't have a clear understanding of voltage/current (which is OK, takes a while...).  Current only matters if the battery can supply less than what the board+attachments is trying to use.  It doesn't matter if the battery can supply 100x the current you need; e.g. you can power a tiny LED off of a car battery, with the proper resistor.  I'm pretty sure the 1.2A battery will be enough current (I've not used the voice recognition module), and the 5x1.2V pack probably supplies at least that much current if needed.
I
« Reply #2 on: May 07, 2012, 09:00:24 AM »
many thanx man for the info and sorry for bad knowledge in electronics i'm still new in this filed
Last post May 22, 2007, 10:35:15 AM
by ed1380
Last post September 09, 2007, 09:21:30 AM
by HDL_CinC_Dragon
Last post January 25, 2008, 07:53:52 PM
Last post March 21, 2012, 05:52:53 PM
