Author Topic: what type of motor controller is this  (Read 418 times)
Offline aaa3aTopic starter
« on: May 07, 2012, 08:56:45 AM »
i have this motor controller TB6612FNG like the one in this image
in the project designer there is tow types of it 2 pins and 3 pins which one of this is mine
and i'll connect the motor supply voltage from 6v 4AH battery pack and also will supply the vcc for the driver from the same battery after using 5 volt voltage regulator as it recommend 5 volt for vcc and then connect the ground of the battery to the ground of my Axon II is this configuration right or should i use something else
Re: what type of motor controller is this
« Reply #1 on: May 07, 2012, 09:18:15 AM »
if there is a link for demo shows how to connect this motor driver with axon  plz add it
  • Helpful? 107
« Reply #2 on: May 07, 2012, 01:32:58 PM »
Both! Just depends on how many controller pins you wanna use - both will work.
RTFM
Last post April 16, 2007, 05:04:43 PM
Last post November 02, 2009, 02:43:09 AM
by Joker94
Last post May 06, 2011, 07:17:59 AM
by newInRobotics
Last post September 04, 2012, 08:14:23 AM
by Batienzaxcore
