Author Topic: axon2 and usb serial  (Read 402 times)
Offline jeromeTopic starter
« on: May 10, 2012, 10:33:22 AM »
Hello everyone,
I tried to send and receive data trough the usb serial port on axon2 board. I am using last WebbotLib version in c++ and AVRstudio4.
When I sended data from the axon2 to the pc it's works perfectly but when I tried to receive data from the pc, the fourth bits look wrong.
I used the function read() from an instance UartHW. To know what I am receiving, I am sending back the data using a small function to transform each bit in byte
some example :
If I sended 1 from the pc to the board I received 0011 0001
When I send 255 I received : 0011 0010
My code source is here : https://github.com/bechu/hexapod/tree/master/src_win
And the python client here : https://github.com/bechu/hexapod/tree/master/talker
Does one of you ever encounter this problem ?
Thanks in advance,
jerome
  • Helpful? 107
Re: axon2 and usb serial
« Reply #1 on: May 11, 2012, 12:53:33 PM »
Don't believe it's a WebbotLib uart problem - as its kinda fundamental to most people. Equally don't have time to wade through all of your code. But I did notice in protocol.cpp you have surrounded a while loop that reads from the uart with CRITICAL_SECTION so your while loop will run with hardware interrupts disabled --- including UART receive/xmit complete interrupts. Looks odd to me!
Axon2 4sale
Started by RKM83 Misc
Last post October 23, 2010, 08:18:35 AM
by RKM83
Last post December 20, 2010, 11:26:18 PM
by GrooveHolmes
Last post April 13, 2011, 01:33:28 PM
by Webbot
Last post February 01, 2012, 04:16:35 AM
by billhowl
