Author Topic: A beginner's problem [SOLVED]  (Read 499 times)
Offline allahjaneTopic starter
« on: May 11, 2012, 07:54:18 AM »
HI people !
i'm just a beginner so i started out by making a simple single LED blinking circuit with the AVR atmega 16.
it has just a voltage regulator at vcc and i have interconnected VCC with AVCC directly.
the program is to toggle HIGH/LOW  pins on PORTC high  each sec..
the program compile successfully
However on running the code on the MCU  after programming the hex on its flash all the pins of the chip whether port A,B,C or D remain HIGH constantly forever....
just to make clear for some people ..... HIGH = +5v
the code is as below.. I'm using AVR studio 4
#include <avr/io.h>
#include <util/delay.h>
#define F_CPU 8000000
int main(){
DDRC = 0xFF;
while(1)
_delay_ms(1000);
PORTC=0xFF;
_delay_ms(1000);
PORTC=0;
return 1;
also i have set the frequency in AVR studio's project configuration to 8000000
why isn't it working?
« Last Edit: May 13, 2012, 01:41:27 AM by allahjane »
Offline newInRobotics
  • Helpful? 45
  • N.I.R.
Re: A beginner's problem
« Reply #1 on: May 11, 2012, 08:25:11 AM »
AFAIK, You don't have to connect AVCC to anything for what You want to do, try leaving it disconnected.
Try following code:
#include <avr/io.h>
int main()
      DDRC |= (1 << DDC0);
      for(;;;)
             _delay_ms(1000);
             PORTC &= ~(1 << PORTC0);
             _delay_ms(1000);
             PORTC |= (1 << PORTC0);
Plug Your LED to Port C pin 0;
Offline joe61
« Reply #2 on: May 11, 2012, 01:24:36 PM »
This is correct.
Your code looks ok for what it does, and I don't see how it could affect the other ports. Can you post a schematic?
What does studio do when that's set? I assume it changes the fuse byte, but can you post what it's setting it to?
Joe
« Reply #3 on: May 13, 2012, 01:40:56 AM »
Try following code:
#include <avr/io.h>
int main()
      for(;;;)
             _delay_ms(1000);
             _delay_ms(1000);
THANKS A TONNN BRO! YOU'RE A GENIUS ITS WORKING NOW! ;D ;D ;D ;D ;D ;D ;D ;D
can you explain me what i was doing wrong? atleast to me i think using the vcc gnd instead of avcc gnd pin was one of the problems
also i dont get that bitwise OR and AND operations.
« Last Edit: May 13, 2012, 01:42:48 AM by allahjane »
  • Helpful? 45
  • N.I.R.
Re: A beginner's problem [SOLVED]
« Reply #4 on: May 14, 2012, 04:38:11 AM »
I'm glad it worked  :D
Not sure, though, what was wrong with Your setup, or code.
Bitwise manipulation allows You to SET or CLEAR (set HIGH or LOW) any single pin of microcontroller without affecting other pins, as opposed to switching whole section of pins with Your code.
I'll try to explain, so bear with me  ;D
PORTC |= (1 << PORTC0) translates into:
PORTC = PORTC | (1 << PORTC0)
To expand on the above bitwise operators work in this way:
To SET required bit You use | (OR) operator.
| (OR) operator needs at least one 1 to produce 1, if that does not make sense - read on...
00001010 |
00001101
00001111;
10100101 |
01010110
11110111;
<< (shift left) operator shifts all bits by given number to the left
00000001 << 5 = 00100000;
00000001 << 1 = 00000010;
01010101 << 1 = 10101010;
All mnemonics (memorable names for ports and pins) in our original line PORTC |= (1 << PORTC0) actually means:
  • PORTC is a set of pins which belong to C block in a microcontroller; it is by default set 0 (0x00 in HEX; 0b00000000 in binary) every time You start microcontroller.
  • 1 in binary is 0b00000001.
  • PORTC0 simply means pin 0 of port C.
Our line PORTC = PORTC | 1 << PORTC0 now translates to:
PORTC = 00000000 | (00000001 << 0) =
= 00000000 | 00000001 =
= 00000001;
Can You see now that this way You do not affect other pins apart from the one You need?
To CLEAR required bit You use & (AND) operator and ~(NOT) operator:
PORTC &= ~(1 << PORTC0), which translates to PORTC = PORTC & ~(1 << PORTC0).
& (AND) operator requires two 1s to produce 1...
00000101 &
11110110
00000100;
~ (NOT) operator inverts all bits changing all 1s to 0s and all 0s to 1s.
~00000000 is equal to 11111111;
~01010101 is equal to 10101010;
~00000001 is equal to 11111110;
Lets say that Your LED is shining now meaning that Pin 0 of Port C is set HIGH, therefore PORTC = 0b00000001;
Our line PORTC = PORTC & ~(1 << PORTC0) now translates to:
PORTC = 00000001 & ~(00000001 << 0) =
= 00000001 & ~(00000001) =
= 00000001 & 11111110 =
= 00000000;
Once again, You can CLEAR one pin only without having effect on others.
Info provided here is based on Bitwise Operators in C and C++: A Tutorial by Alex Allain.
Hope this was clear enough to understand.
« Last Edit: May 14, 2012, 05:23:30 AM by newInRobotics »
Last post May 17, 2009, 04:47:17 PM
by catalinene33
Last post July 24, 2009, 09:59:04 PM
Last post June 26, 2010, 12:01:49 PM
by dellagd
Last post January 29, 2011, 09:40:26 PM
by greasemonkey94
