Author Topic: axon2 and pwm software  (Read 458 times)
Offline jeromeTopic starter
« on: May 11, 2012, 11:46:11 AM »
Hello,
I am building an hexapod, using the axon2 board,
I am succesfully creating servo hardware pwm controller. But failing with software one.
Does anyone know how to configure and used pwm software with the webbotlib library (by hand, without the project designer) ?
Do you know which pin are available for servo software pwm ?
If you have some source code I really appreciate that
Jerome
ps : I don't want to user project designer because I want to expand my configuration on the go.
  • Helpful? 107
Re: axon2 and pwm software
« Reply #1 on: May 11, 2012, 12:45:37 PM »
Any digital I/O pin
Edit: you can generate the signal on any I/O pin but remember that you will need to provide ground and power to the servo as well and so that should be from the unregulated power pins.
Eh?
« Last Edit: May 11, 2012, 01:15:46 PM by Webbot »
Last post January 10, 2011, 02:46:54 AM
by enekux
Last post August 03, 2010, 11:18:17 AM
by Aberg098
Last post January 29, 2011, 07:32:25 AM
by thx123
Last post December 20, 2010, 11:26:18 PM
by GrooveHolmes
