Author Topic: error in vrbot(voice recognition) example code  (Read 2043 times)
Re: error in vrbot(voice recognition) example code
« Reply #30 on: June 08, 2012, 07:33:12 PM »
After plugging in your battery and VRbot, turn everything on.
Then measure two things:
1) battery voltage
2) voltage for the VRbot
Offline aaa3aTopic starter
« Reply #31 on: June 08, 2012, 07:39:46 PM »
battery voltage 5.89volt
vrbot voltage 4.98volt
i'm asking if we can use chat as u and me online or u prefer posting?
« Reply #32 on: June 08, 2012, 09:58:44 PM »
The voltage seems fine, but I'm going to ask you to charge that battery anyway just in case. Then retry.
Using your multi-meter, double check the connectivity of your wires, making sure it's all solid.
It worked before, and then you said it sometimes worked and sometimes didn't. It could be a wire was slowly breaking. Check to make sure the wires look ok.
ps - posting is best, as it allows other people to chime in their thoughts and search for this info online
« Last Edit: June 08, 2012, 10:00:13 PM by Admin »
« Reply #33 on: June 10, 2012, 03:25:57 AM »
i just want you to check my code on your vrbot module this could solve the problem if it is work so my module could be damaged
as it must respond to the trigger command at least and there is no prob. in the wiring all the cable ok
tell me if my code work with you
by the way iam using UART 0 for the vrbot
« Reply #34 on: June 17, 2012, 06:25:07 AM »
I am confused on which code isn't working.
Is it not the compiled .hex for USB to serial that is causing you issues, and not your custom code?
« Reply #35 on: June 17, 2012, 02:36:42 PM »
i'm talking about the vrbot i sent have you tested it on your vrbot module the usb cable code worked once then died may be there is fault in the usb code or baud rate but if the vrbot code was good it should be working fine if the vrbot module is fine as it is direct connected to the uart so test the code i've attached on your vrbot to be sure the code i'm use is good so my module is faulty then
thanx
« Reply #36 on: June 17, 2012, 04:03:38 PM »
So, you are able to program voice commands fine into your robot using the USB to serial hex, right? And you tested that and it works, right?
« Reply #37 on: June 18, 2012, 06:18:03 AM »
yes that's happened once i'm talking now about the vrbot code i wrote is it work on your vrbot module this will prove it is ok or not
« Reply #38 on: June 21, 2012, 11:33:05 AM »
Follow these steps:
1) recharge your battery - it's too low and maybe even dead
2) verify it works using VRbot GUI software and the USB to serial code
(you said this works fine, right?)
3) Use the example .c code *without* any modification other than that it's for the original Axon:
http://societyofrobots.com/downloads/Axon2_Voice_Recognition_Software.zip
« Reply #39 on: June 23, 2012, 03:10:53 PM »
i've removed all the devices from the axon board except the vrbot module and the motor driver and did a test for the usb-serial code with the module software(vrbot gui ) and it can connect now to the module and tested the commands but when i flash the vrbot code the one you wrote and the one i am wrote no response from the module to my voice.i've replaced the servo commands in the code with a print msg just for check and  used hyper terminal to see the output of the rprintf function and  nothing happened
please check the code i wrote and sent to you before or even yours there something wrong i've replaced the servo commands in the code with a print msg just for check
you will find my code in this file
http://www.societyofrobots.com/robotforum/index.php?action=dlattach;topic=15650.0;attach=6427
regards
Last post October 18, 2007, 03:52:08 AM
by Robo73
Last post March 16, 2008, 03:52:41 AM
by Toymaker
Last post June 16, 2008, 09:25:03 AM
by airman00
Last post December 21, 2012, 12:11:53 PM
