Author Topic: good cheap vacuum former under $50 (not $500)  (Read 2934 times)
Offline drcrashTopic starter
« on: July 16, 2007, 03:34:09 PM »
The vacuum forming tutorial makes it sound like a vacuum former has to cost $500 or so, even if you make it yourself.
I wrote an "Instructible" (how-to) on how to make a good, cheap, upgradeable vacuum former for under $50, using your kitchen oven and a vacuum cleaner:
http://instructibles.com/id/E8RW98YF3C4XLCQ/
Here's a movie of it in action:
You can add a standalone oven made from a two-burner hot plate and disposable aluminum pans for under $30.
You can add a high vacuum system for forming thick plastic for about another $50.
This stuff and more is linked at the Vacuum Former Plans blog at www.VacuumFormerPlans.com
« Last Edit: July 16, 2007, 03:44:56 PM by drcrash »
Offline Dosbomber
Re: good cheap vacuum former under $50 (not $500)
« Reply #1 on: July 16, 2007, 03:54:24 PM »
Excellent video.  Clears up some of the confusion I had from the written version of the instructable.
Dosbomber
Offline Brandon121233
« Reply #2 on: July 16, 2007, 08:13:58 PM »
I don't know too much about vacuum forming... but do you know what the maximum thickness of plastic you can use to make parts out of?
        —Thomas Edison
« Reply #3 on: July 17, 2007, 07:04:07 AM »
With a simple easy setup like in the video, you can form plastic up to about a quarter of an inch thick.  I've made parts the size of the one in the video that my wife and I can both stand on without breaking them.  (Of course the rigidity & strength depend on the shape.)
When you form thick plastic as shown in the video, without a high vacuum system, you don't get very sharp detail---the shape gets smoothed out by the thickness of the plastic, and somewhat more.
You can get better detail with a high vacuum system, which pulls several times harder than a vacuum cleaner.  (You can use a converted bike pump, or electric tire inflator, or kitchen food sealer, or a "nebulizer" pump from a thrift store.)  For maximum detail, you want to suck the plastic into a concave mold, rather than draping it over a positive mold as in the video.  (The side of the plastic that's against the mold has the best detail;  the other side is smoothed out more.)
I'd think that for most robot purposes, plain vacuum forming of 1/8" plastic over a positive mold with a vacuum cleaner would be fine---you can make smooth compound curves with curve radii of about 3/16" for convex stuff, or 3/8" for concave areas.  (Somewhat finer detail does show through, but in muted form.)
People seem to like rounded-off robot stuff, and the parts are generally convex, so a cheap easy vacuum forming setup can be very useful for making your bot look professionally made.
With a fancier setup, you can form plastic up to 3/8" or 1/2" thick, but I think that's overkill for most robot purposes, and I haven't tried it yet.
« Reply #4 on: July 17, 2007, 07:06:19 AM »
Let me know what you found confusing.  (I intend to edit the Instructable.  It was a bit of a rush job, and should have had the video to start with.)
« Reply #5 on: July 17, 2007, 07:35:15 PM »
Impressive!
Wish you made this video 2 years ago!  :P I would have definitely done this.
You might want to go in to more detail about creating a proper vacuum - I found this to be the hardest part.
Just for reference:
http://www.societyofrobots.com/materials_vacuumforming.shtml
Last post August 04, 2009, 03:48:47 AM
by Truckstop
Last post January 24, 2009, 01:30:50 PM
by Qubix
Last post April 03, 2009, 10:33:55 AM
by RiO
Last post January 06, 2010, 03:49:58 PM
by z.s.tar.gz
