Author Topic: WebBot Lib and SRF08  (Read 634 times)
Offline Max WebTopic starter
« on: May 19, 2012, 11:34:04 PM »
I'm encountering yet another strange problem while using a Devantech SRF08 (firmware version 8 ) with WebBot Lib 2.09 (C version).
The upper code outputs the correct distance while the original version always outputs 0 (zero):
This is the code I am using:
//This part of the code works!
i2cMasterWriteRegister(&sonar.i2cInfo, 0, 0x51); // Send command to register 0
DISTANCE_TYPE val=4;
uint8_t response[4];
// Read registers 0,1,2,3
delay_ms(80);
if(!i2cMasterReadRegisters(&(sonar.i2cInfo), 0, 4, response)){
rprintf("Error reading SRF!\r\n");
while(i2cMasterReadRegisters(&(sonar.i2cInfo), 0, 4, response)){
if(response[0]!=255){
// Ranging has finished
val = response[2]; // get high byte
val = (val << 8) + response[3]; // put in low byte
break;
rprintf("sonar(CUSTOM): %u, %d, %d\r\n", val, val, sonar.i2cInfo.addr);
//But this part (library code) fails...
// -------- Start Devantech SRF08 sonar-------
// Read the Devantech SRF08 sonar and store the result in sonar.distance.cm
distanceRead(sonar);
// The value can be printed using %u eg rprintf("Distance=%u",sonar.distance.cm);
// or dumped using:
rprintf("sonar(LIB): ");
distanceDump(sonar);
rprintfCRLF();
// -------- End   Devantech SRF08 sonar-------
I believe that I found out which part of the library's code causes this problem (excerpt from 'SRF08.c'):
static void getReading(Devantech_SRF08* device){
if(device){
const I2C_DEVICE* i2c = &(device->i2cInfo);
while(i2cMasterReadRegisters(i2c, 0, sizeof(response), response)){ //I think it fails over here!
DISTANCE_TYPE val = response[2]; // get high byte
val = (val << 8) | response[3]; // put in low byte
device->distance.cm = val;
device->ldr = response[1]; // Store the light level
break;
Because the sensor works perfectly while using the upper code (with the delay included), I think it does not react to any I2C requests while it's measuring...
My SRF's firmware version is 8. Am I right with my suspicion or am I using the library in a wrong way? Is my sensor broken?
How could this issue be fixed in a better way than duplicating the SRF's code?
Max Web
« Last Edit: May 19, 2012, 11:39:18 PM by Max Web »
  • Helpful? 107
Re: WebBot Lib and SRF08
« Reply #1 on: May 20, 2012, 12:25:19 PM »
Try replacing the SRF-08.c in WebbotLib with the attached.
Then re-compile WebbotLib, ie from a command prompt, change to the install directory and type 'make'.
Then rebuild your project and let me know if it fixes the problem.
As you can prbably tell - I don't own e3very sensor on earth so some drivers are just written based on what the spec sheet says. Sometimes they are a bit 'grey'.
« Reply #2 on: May 20, 2012, 12:48:15 PM »
the new file fixes the problem, the SRF08 works fine now - thanks!
This fix might also apply to the SRF02 - I don't possess one any more but their I2C interface is quite similar.
Max Web
  • Helpful? 107
« Reply #3 on: May 20, 2012, 01:06:22 PM »
+1 Help for being an educated guinea pig !
Last post August 10, 2008, 12:30:36 PM
by yukolin
Last post November 23, 2010, 04:30:32 AM
by zuppaman
Last post July 29, 2010, 03:13:42 AM
by paulstreats
Last post July 30, 2010, 05:45:43 AM
by Webbot
