Author Topic: what do i need to make a propeller spin super fast?  (Read 2369 times)
Offline S. KarimTopic starter
« on: July 16, 2007, 04:01:44 PM »
ok i have a basic propeller facing the ground, im looking to make this spin so fast it generates enough lift below it to "hover" off the ground.
are there any lightweight motors i can get made for this kind of stuff? what kinds of rpms am i looking for? is it possible that a company would be selling gearboxes made for speed rather than for reduction (torque)?
any general to specific info is helpful. im making a hovercraft to float off the ground, using 3 propellers but im not sure about the motors ill need and what kind of electronics/battery with it.
thanks!
Offline dunk
Re: what do i need to make a propeller spin super fast?
« Reply #1 on: July 16, 2007, 05:07:08 PM »
you probably want to look at electric RC aircraft motors for something this specialised.
try asking on a RC aircraft forum as those guys will know far more about it than any one here.
i say this product a while back:
http://www.skyhooks.ca/kp.htm#KP44
maybe it is what you are looking for?
Offline KambeiX
« Reply #2 on: July 16, 2007, 06:21:10 PM »
hmm for fast motors use a brushless one or a normal ungeared or light geared dc motor as they are cheaper. airplane R/C stores should give you more info on the output power and power/weight rating.
For battery, LiPo are the lightest.
Offline hgordon
  • Helpful? 7
« Reply #3 on: July 17, 2007, 07:08:16 AM »
Look at http://www.rcgroups.com/vtols-360/ for suggestions
Surveyor Corporation
  www.surveyor.com
« Reply #4 on: July 22, 2007, 11:21:54 AM »
When you say hover, do you mean like a helicopter, or a robot sitting on top of an inflated bag (hovercraft)?
If a helicopter, dunks ducted fan suggestion wont work:
At 32g of thrust it will draw 2.8 Amps. Its weight is 32g.
« Last Edit: July 22, 2007, 11:22:56 AM by Admin »
Offline dunk
« Reply #5 on: July 22, 2007, 05:34:56 PM »
Outside Dia. 46mm, inside diameter 44mm (1-3/4"). The body length is 36.5mm and the nose come protrudes an additional 8.5mm Capable of providing 82g of thrust on 4.8 VDC. Minimum tailpipe diameter is 38mm, with a maximum 6? taper. At maximum thrust, this little fan will draw 8 Amps. At 32g of thrust it will draw 2.8 Amps. Its weight is 32g.
doesn't leave much space for batteries and other components but an impressive little fan never the less.
« Reply #6 on: July 22, 2007, 05:56:53 PM »
It appears I cant read . . . lol :P
Last post February 10, 2009, 09:24:59 PM
by 4by4
Last post May 19, 2009, 03:14:51 PM
Last post April 20, 2011, 02:32:55 AM
by Graynomad
Last post November 14, 2011, 05:31:43 AM
