Author Topic: help with an RC boat  (Read 700 times)
Offline kyleworTopic starter
« on: June 02, 2012, 03:37:43 PM »
ok, second post here, so apologies for the lack of specific details (because i just dont know the actual words i mean)
im building an RC boat, and im having a couple issues. namely that i cant fit the parts i have into the hull i designed (i recall something about design/assemble ratios and im sure mines close to 20 mins/3 weeks already) i now have to take the battery pack apart to get to the signal receiver, then build a circuitboard using that reciever, a small motor i pulled out of another RC boat, and a servo for the steering. is there anyone that could give me a bit of guidance on how to build that board? if pictures of what im working with and how much space i have would help i can upload them
Offline corrado33
  • Helpful? 11
Re: help with an RC boat
« Reply #1 on: June 03, 2012, 09:16:56 AM »
Your post makes no sense.
Why would a signal receiver be in a battery pack?  What else do you need to control.  What type of motor are you using.  What type of servo are you using?  How are you controlling the boat?
Without answering these questions no one will be able to help you.
« Reply #2 on: June 03, 2012, 11:20:15 AM »
the battery pack is a plastic housing that holds 4 AA batterys with the board underneath, its an rc boat so obviously a remote control, 2 channel to be more secific, i have no idea what kind of motor it is because i pulled it out of another rc boat and its sealed up in plastic with no markings, same with the servo but probably going to switch to a spare hs311 i have. and i already said everything i need to control, the motor (for the prop), and the servo (for the rudder) motor goes forward and stop, rudder goes left/right
Offline tomcharley
« Reply #3 on: June 04, 2012, 12:48:49 PM »
Dear Kylewor,
  Pictures would definitely help if you have them.  What is the problem exactly?  Do you need help fitting everything into the hull or do you want advise on how to build the circuit board?  If you want help with a circuit board, the electronics section of the forums might be the place to post.
  As for problem you have fitting everything into the hull, it is tough to figure out a solution without pictures and/or dimensions of the hull and the equipment that you want on-board.  Is the hull a hollow plastic shell or a thick chunk of Styrofoam?  Some basic advise would be to try to put your higher density stuff in the bottom of the hull to keep a low center of gravity.  Also, don't stack too much stuff on the deck because it will raise the center of gravity (think of how SUVs are more prone to flipping), and because you don't want your electronics getting wet.
  One option that you have would be to add pontoons to the sides.  This would make the boat far less maneuverable, but you would have so much more room on top to put stuff, and you wouldn't have to worry about the boat flipping.
  On a side note, although this is just an internet forum, we are trying to give technical advise.  It benefits everyone if you really think out your post and try to be as clear and concise as possible.  Corrado said that your post made no sense because it is confusing.  You don't use proper punctuation or any capitalization, and it results in run-on sentences and nonsensical statements.  It makes your post very difficult to read and interpret at a glance.  Please take your time and plan out your post a little more formally.  Consider that we know nothing about your current problem or the tools that you have at your disposal, and then educate us about your situation.
~Tom
Last post December 02, 2009, 06:43:52 PM
by blackbeard
Last post July 11, 2010, 06:42:44 AM
Last post February 28, 2011, 09:48:23 PM
by amarquez87
Last post September 13, 2011, 12:22:02 PM
by ryan31627
