Author Topic: Interfacing Vibrating Motors with Arduino Uno  (Read 870 times)
Offline mike_coTopic starter
« on: June 03, 2012, 01:41:03 PM »
Hi this is my first post, I just have a small question to ask about a project I'm working on.
I am trying to use these vibrating motors with the Arduino Uno board:
http://www.robotshop.com/ca/productinfo.aspx?pc=RB-Sbo-46&lang=en-US
The buzzers run on 80mA of current, while the Arduino can take 50mA. I know I need to build a small circuit to get this working, can anyone point me in the right direction? Thanks.
Offline mstacho
  • Helpful? 10
Re: Interfacing Vibrating Motors with Arduino Uno
« Reply #1 on: June 04, 2012, 07:49:25 AM »
Probably the easiest way to do any DC motor control from a microcontroller is to use an H-Bridge circuit.
You can buy H Bridges as integrated circuits or breakout boards, although if all you need is 80mA you're going to be going into overkill mode by buying one :-P
However, if you're going to be doing other projects with bigger motors, it's always good to have a few.  I use these: http://parts.digikey.com/1/parts/577889-ic-h-bridge-5a-dc-motor-to220-7-tle5206-2.html although there are a ton of others around.
If you want to play with circuits, though, an H-Bridge is only 4 transistors and some diodes.  Just be sure you're choosing the right transistors (this is...sadly something I don't know how to do, but am interested in learning).
Keep one thing in mind, though: if you're  using an H Bridge like the one I just showed you, you have to use TWO PWM outputs, not just one.  If you modify it with a bit of logic circuitry, you can only use one PWM and one digital IO pin (not in PWM mode, just on/off).  This is because you need to be able to set the direction of motor as well as its speed.
MIKE
Offline jkerns
  • Helpful? 10
« Reply #2 on: June 04, 2012, 08:31:57 AM »
I assume there is no need to change the direction of the motor (since it's just a vibrator), so one would really only need one corner of an H bridge.
http://www.ltu.edu/engineering/mechanical/robotics_engineering.asp
Last post December 12, 2010, 08:29:26 PM
by cpctc1234
Last post March 25, 2011, 09:37:46 AM
by knip
Last post September 22, 2011, 01:51:45 AM
by WaterPig Master
Last post October 04, 2012, 06:06:52 AM
by newInRobotics
