Author Topic: Help explaining the mechanics behind this lego mindstorm biped?  (Read 759 times)
Offline superfly501Topic starter
Hello,
I came across this video of a lego mindstorm
Biped Lego Mindstorms NXT X 2 5 First testing on steps
I only know of using servo's for positional control like that, but looks he is using continuous motors. How do the continuous motors hold position like that? Is it a belt or  gears? Any name for this type of mechanics? I'm guessing his method is much better at fine control than servos. Also is this type of mechanics closer to what we use in modern robotics?
Offline jkerns
  • Helpful? 10
Re: Help explaining the mechanics behind this lego mindstorm biped?
« Reply #1 on: June 11, 2012, 10:23:15 AM »
The Lego motors provide rotation feedback.
So, they can work like a servo except you need to put the feedback loop in your own code instead of in the servo itself.
http://www.ltu.edu/engineering/mechanical/robotics_engineering.asp
Last post May 07, 2011, 10:55:32 AM
by mr roboto
Last post June 07, 2008, 12:13:52 PM
by Rebelgium
Last post January 09, 2011, 08:02:24 PM
by raven.chrono
Last post April 07, 2011, 06:17:54 PM
by mr roboto
