Author Topic: Webbotlib software UART compile error in C  (Read 637 times)
Offline klimsTopic starter
« on: June 13, 2012, 05:57:47 AM »
I'm back again with another compile error :(
I am getting compile errors when trying to include a software UART in my project. The errors I'm getting are:
lib/gen_SerialServoDriver_uart.c: In function '__vector_14':
error: 'PB0' undeclared (first use in this function)
...and so on all relating to uses of PB0.
I have tried many other pins but I get the same compile error (but the pin changes).
I have been able to successfully compile using the pins that didn't work in other project device (eg: PB0 on another device as a digital output).
Any ideas guys? Can anyone confirm for me if they are able to use software UART in their project?
Thanks.
  • Helpful? 107
Re: Webbotlib software UART compile error in C
« Reply #1 on: June 13, 2012, 04:26:24 PM »
Its another blessed AVR anomoly. On some chips they call the pins PB0, PB1 etc but on the ATmega328P they decided to call them PORTB0, PORTB1 etc.
So until I can get a fix out then change
#define TRANSMIT_PIN   PB0
to
#define TRANSMIT_PIN   PORTB0
« Reply #2 on: June 13, 2012, 05:19:31 PM »
Awesome. Thanks Webbot!
  • Helpful? 107
« Reply #3 on: June 13, 2012, 05:23:16 PM »
No worries! New Project Designer now released that fixes the problem.
Last post September 04, 2008, 07:53:27 PM
Last post November 14, 2010, 06:54:46 PM
Last post March 07, 2012, 05:58:02 PM
by jzaun
Last post February 04, 2013, 11:09:33 AM
by jwatte
