Author Topic: how CCD work in IR sensor  (Read 475 times)
Offline shirTopic starter
« on: June 21, 2012, 11:04:38 AM »
HI,
I want to ask how CCD work in Sharp IR sensor like GP2D12?
The sharp IR sensor shoots out a concentrated (by the lens) IR-light beam
The beam hits an object, and reflects back in all directions.
As the length from the object  increases, the returning lights degree will be steeper.
How the beam that hit the CCD,translate into length(x in my figure) or into angle?
I can measure the X by the hit pf the beam?
I know the b(the length between the eye and the ccd of the sensor) so i can know with b and the x the length the object is.
Thank u and sorry for the mistakes in english.
Shir
Re: how CCD work in IR sensor
« Reply #1 on: June 23, 2012, 02:29:12 PM »
The "CCD" is an array of photo receptors with a lens in front of the array, so the reflected light dot will be concentrated on a small number of the receptors, which depends on the distance to the target. The calculation, based on the brightest lit (averaged) receptor is done inside the sensor.
« Reply #2 on: June 23, 2012, 02:53:35 PM »
The calculation, based on the brightest lit (averaged)eceptor is done inside the sensor receptor is done inside the sensor.
Ok,so how exactly the calculation is made inside the sensor?
it's depand on the length of the brightest lit receptor from the middle ,from the center of the sensor,from the first receptor or somthing else?
The location of the brightest lit receptor is importent to the sensor beacuse it's considerate with it in the Microprocessor?
Are u understand my question?
Thank u !!!
Shir
« Reply #3 on: June 23, 2012, 03:15:00 PM »
What goes on inside the PSD's is proprietary - why do you want to know?
Not entirely.
Last post May 29, 2009, 06:36:43 AM
by Tomas
Last post July 16, 2009, 11:55:49 AM
by Ocelot
Last post November 18, 2010, 09:53:05 PM
by Redcap
Last post December 22, 2011, 06:18:30 AM
