Author Topic: Just a quick color sensor question...  (Read 385 times)
Offline nijmegen96Topic starter
« on: June 23, 2012, 10:06:04 PM »
Just to keep it short and sweet.
If I make this:
http://letsmakerobots.com/node/23768
Will it work as fast and reliably as this?:
http://tiltedtwister.com/tiltedtwister2.html
Just a note, I plan on using one RGB LED instead of the 4 colors, and how do the lego sensors work? Doesn't look like they flash the different colors like the homemade one. Could i just have all the colors (white) for it to reflect the color back? Also could I just buy the Lego color sensor and make it work with a microcontroller?
Re: Just a quick color sensor question...
« Reply #1 on: June 24, 2012, 10:42:31 AM »
[...] how do the lego sensors work? Doesn't look like they flash the different colors like the homemade one.
"LEGO sensor uses a RGB LED, and successively shines red, green and blue light on the object. Reflected light is collected by a light sensor sensitive to all wavelength."
Yes, if you get a dedicated color sensor chip (plenty to find at TAOS)
Sure, it seems to just output an analog voltage.
« Reply #2 on: June 24, 2012, 02:07:47 PM »
Alright Thanks!
Last post March 16, 2007, 08:40:45 AM
by Somchaya
Last post June 19, 2007, 04:32:39 AM
Last post September 17, 2007, 06:32:06 AM
Last post March 26, 2008, 03:06:36 PM
by AndrewM
