Author Topic: What is ground?  (Read 2589 times)
Offline garriwilsonTopic starter
What is ground?
« on: July 17, 2007, 07:06:40 PM »
When you guys say like attach something to ground where is that??? To any ground on the circuit or some specific place? Please help! If you don't know know what I'm talking about post a reply asking for more info.
admin edit: changed subject line to something more useful than 'I need major help people!!! Help me!! Please!!'
« Last Edit: July 19, 2007, 12:45:55 PM by Admin »
Ground and power
« Reply #1 on: July 17, 2007, 07:07:15 PM »
Is ground negative and is power positive I don't get it?
Re: I need major help people!!! Help me!! Please!!
« Reply #2 on: July 17, 2007, 07:17:18 PM »
Also on the 9v battery clip, which wire is positive and which one is negative? And where do you solder it to?
Offline Robotboy86
« Reply #3 on: July 17, 2007, 07:18:33 PM »
Ground is "negative" part of the battery.
Offline Kohanbash
Re: Ground and power
« Reply #4 on: July 17, 2007, 08:29:32 PM »
In DC (ie batteries) the - side is usually represented as ground ( for simple power/ motor circuits). and the + side is where the voltage is fed in from the + side of the battery
( Just to head off any rants. I know electrons technically flow from - )
Offline Kohanbash
« Reply #5 on: July 17, 2007, 08:47:59 PM »
On a battery each side is labeled + or -. On standard 9v US batteries the smaller terminal is +.
Its usually a good idea to get a connector that goes to the battery instead of soldering leads directly to the battery.
http://www.christianbook.com/Christian/Books/product?item_no=756045&event=1052CLO
(I'm not promoting any particular site however it came up when I googled the connector, it has a picture, and the price looked good (cheaper than digikey))
Offline Robotboy86
« Reply #6 on: July 17, 2007, 09:23:55 PM »
lol i wrote the same response as you at work, but got a call and forgot about it..
Ground is normally -.  Electrons COME from - technically :P
Needless to say:
A long time ago, someone made a big oops. lol
