Author Topic: Where to make connections on Xbee Development board  (Read 532 times)
« on: June 28, 2012, 01:32:14 PM »
Hello everyone,
I am having issues locating where to make the connections from my Xbee to my Axon II.  It doesn't help either that this board has barely any documentation.
Tx > RX, Rx > Tx, etc.  That is not my issue. I am having trouble locating these on my Xbee board.
There are some solder points on the board that look like this
VCC            DOUT
DIN             DSR
RESET         RSSI
PWM 1        6KGD
SLEEP_RQ   GND
My guess is that I need VCC (Voltage line), DIN (Rx), DOUT (Tx), and of course Gnd.  Could someone confirm this?  Also I dont know what voltage I need to supply.
Please help.
Offline Gertlex
  • Helpful? 23
Re: Where to make connections on Xbee Development board
« Reply #1 on: June 28, 2012, 05:46:52 PM »
Link to which board you're using so we can be certain in pointing you at the right holes.
I
« Reply #2 on: June 28, 2012, 08:52:55 PM »
http://ftp1.digi.com/support/documentation/xbibudev_schematic.pdf
Here is a picture.  Maybe it will help even though the quality is awful.
« Last Edit: June 28, 2012, 09:02:15 PM by Mastermime »
Offline Gertlex
  • Helpful? 23
« Reply #3 on: July 03, 2012, 11:04:20 AM »
Sounds like you have the right holes in mind. I'm not sure what voltage to use, either, but I didn't look too closely.
That's also a large complex board. If you're doing simple stuff the combination of these two boards might be easier and more straight-forward to work with.
http://www.parallax.com/StoreSearchResults/tabid/768/txtSearch/xbee/List/0/SortField/4/ProductID/664/Default.aspx (Nice, small, has mounting holes, is not the Sparkfun board.)
http://www.trossenrobotics.com/p/uartsbee (for connecting to computer; the reset button is nice to have for the rare programming issues)
I
« Reply #4 on: July 08, 2012, 07:55:22 PM »
I don't have much programming experience so would configuring and programming the parallax and trossen robotics board be that much easier than configuring this developmental board?  Would it be worth the extra money to buy these boards?
Last post July 12, 2006, 01:49:22 PM
Last post January 14, 2008, 10:39:22 AM
by krich
Last post February 13, 2010, 05:51:46 AM
by little-c
Last post September 29, 2010, 08:08:17 AM
