Author Topic: how does one derive Gruebler's equation ?  (Read 887 times)
Offline tdk93Topic starter
« on: July 09, 2012, 12:57:58 PM »
F=3(n-1)-2l-h
F = total degrees of freedom in the mechanism
n = number of links (including the frame)
l = number of lower pairs (one degree of freedom)
h = number of higher pairs (two degrees of freedom)
This equation is also known as Gruebler's equation.
i'm interested about the first term, that is 3(n-1)
Offline fridgid
Re: how does one derive Gruebler's equation ?
« Reply #1 on: July 11, 2012, 10:43:21 AM »
for plane motion, links can have at most three degrees of freedom. (x/y movement, and z rotation)
the equation is derived from simple proofs by starting with a single link and adding more links
noting that each joint will remove degrees of freedom depending on the joint type.
revolute joints remove two degrees of freedom by preventing x/y movement but allowing z-rotation (so they only /allow/ one degree of freedom)
prismatic joints are the same >> so and so forth for all other joints
the poof is shown by example
e.g. if you start with one link it can have three degrees of freedom
(this equation assumes one of the links is fixed in space relative to something ('grounded')
so for a single fixed link, N=1, L=0,H=0 >> F=0
for two links, say with a revolute joint, the first link is fixed while the other is attached via a revolute joint; N=2, L=1, H=0 >> F= 1
this means that the mechanism (as a whole) will only be able to move in one degree of freedom (in this case rotation)
you can continue this down for more links
keep in mind this formula is not fool proof and does produce errors for unique link configurations (aka parallel bars in plane motion)
tl;d: the 3 is showing that all links have at most 3 degrees of freedom in planar motion, and the (n-1) is from the ground or 'fixed' linked
Last post June 27, 2007, 05:06:43 AM
Last post August 28, 2008, 06:08:41 AM
by Tsukubadaisei
Last post November 22, 2008, 07:17:53 PM
by paulstreats
Last post June 09, 2009, 07:30:13 AM
by genesis
