Author Topic: $50 robot...Code related basic question!  (Read 683 times)
Offline rmoreTopic starter
« on: July 10, 2012, 01:19:39 PM »
Hello All!
This is my first post in here! I am building the $50 robot and it has been a lot of fun so far. I learnt a great deal just by going thru the forum and looking at what problems other people faced while building this robot.
Thank you for this forum. You guys are a great help.
I have a basic question regarding the code. I do not understand how the numbers '44' and '25' were arrived at. Like the numbers in servo_left(44), servo_right(25).
What is the significance of these numbers? Why not use - say 45 and 24 instead? I probably am missing something very simple....but nevertheless please try to answer my question.
Thanks.
Rmore
Offline adanvasco
  • Helpful? 6
Knowledge does not weigh.
Re: $50 robot...Code related basic question!
« Reply #2 on: July 12, 2012, 09:45:38 PM »
Adanvasco,
Thank you for pointing me into the right direction. I now understand the 'magic' numbers.
I did not understand one thing that Admin said though -
     By varying the number - say 22 or 27 instead of 25, you can slow down or speed up your servo.
How is this possible? Isnt the servo supposed to rotate at a constant speed always?
Thanks.
Rmore
Offline ErikY
« Reply #3 on: July 13, 2012, 04:25:13 AM »
Adanvasco,
Thanks.
Rmore
Admin wrote in his tutorial that by modifying a servo, you lose the ability to control angle position but gain the ability to control servo speed.
« Reply #4 on: July 13, 2012, 10:29:21 AM »
Yes, but how exactly does using '22' slow down a servo and '27' increase the speed of the servo?
As far as I understand, we are using two functions - delay_cycles and servo_left/right
Input to 'servo_left' function is speed - say 22.
And this speed (22) is then the input for delay_cycles. So the port is ON for that much of time. (time taken to execute delay_cycles(22).
In next case, the port would be ON for time taken to execute delay_cycles(27).
So the time the port is ON varies in both cases. How does that time variance correspond to different speeds?
I would think its just the servo that is operating for different time intervals (but at same speed).
I am just not getting this.
Please help me understand this concept.
Thanks.
Rmore
Offline newInRobotics
  • Helpful? 46
  • N.I.R.
« Reply #5 on: July 15, 2012, 08:10:22 AM »
Servo does not rotate at constant speed. The further away destination angle is from current angle, the faster servo will rotate. So, if current angle is 0° and destination angle is 2° then servo will rotate slower than if current angle is 0° and destination angle is 15°. By modifying servo and gluing pot at 0° You can vary servo speed instead of destination angle. Does that make sense?
« Reply #6 on: July 15, 2012, 09:16:17 AM »
New In Robotics,
Thank you. Now I do get it. So by modifying the servo, you gain control over servo speed but lose control over servo positioning.
Thanks.
Rmore
Last post December 14, 2007, 01:38:10 PM
by neopj3
Last post May 06, 2008, 11:59:10 AM
by pomprocker
Last post March 18, 2009, 05:51:06 AM
by Ro-Bot-X
Last post September 11, 2010, 10:54:38 AM
by madsci1016
