Author Topic: error programming adc  (Read 618 times)
Offline ram aravindTopic starter
« on: July 17, 2012, 10:59:21 AM »
i need to do this:
whenever i press button ,power goes to d0 input pin and i must carry the task given in if loop:
#include <avr/io.h>
#include <avr/interrupt.h>
int main (void)
   PORTD &= ~(1 << 0); //set port d0 as input
   DDRE |= (1 << 2); // Set LED1 as output
   DDRG |= (1 << 0); // Set LED2 as output
   ADCSRA |= (1 << ADPS2) | (1 << ADPS1) | (1 << ADPS0); // Set ADC prescaler to 128 - 125KHz sample rate @ 16MHz
   ADMUX |= (1 << REFS0); // Set ADC reference to AVCC
   ADMUX |= (1 << ADLAR); // Left adjust ADC result to allow easy 8 bit reading
   // No MUX values needed to be changed to use ADC0
   ADCSRA |= (1 << ADFR);  // Set ADC to Free-Running Mode
  if(PIND==0b00000001)// D0 gets 5v when button is pressed
    ADCSRA |= (1 << ADEN);  // Enable ADC
   ADCSRA |= (1 << ADIE);  // Enable ADC Interrupt
   sei();   // Enable Global Interrupts
   ADCSRA |= (1 << ADSC);  // Start A2D Conversions
   for(;;)  // Loop Forever
ISR(ADC_vect)
   if(ADCH < 128)
      PORTE |= (1 << 2); // Turn on LED1
      PORTG &= ~(1 << 0); // Turn off LED2
   else
      PORTE &= ~(1 << 2); // Turn off LED1
      PORTG |= (1 << 0); // Turn on LED2
but its showing error that ::
error - static declaration of vector_4 follows non static declaration.
plz help me in this..
« Last Edit: July 17, 2012, 11:03:23 AM by ram aravind »
Offline adanvasco
  • Helpful? 6
  • Necessity is the mother of invention.
Re: error programming adc
« Reply #1 on: July 25, 2012, 05:37:52 PM »
Why don't you use a while(1) loop instead of a for loop?
Knowledge does not weigh.
Offline Webbot
  • Helpful? 107
« Reply #2 on: July 25, 2012, 08:21:14 PM »
Are you doing this in an 'h' or 'c' file?
What chip are you using?
Offline greywanderer012345
« Reply #3 on: August 23, 2012, 11:56:31 AM »
This needs to be in your interrupt or your infinite loop. As written, you are only polling the button as soon as the program starts.
This wont fix your current problem, but I'd hate for you to bump into another headache as soon as you solve this one.
Last post July 16, 2010, 03:28:01 PM
by ballbreaker
Last post July 09, 2010, 12:18:44 AM
by Joker94
Last post March 19, 2011, 11:37:02 PM
by ballroomdancer
Last post June 22, 2012, 09:51:33 PM
by ram aravind
