Author Topic: Following A Light  (Read 1087 times)
Offline MegaLaDonTopic starter
Following A Light
« on: July 29, 2012, 07:29:41 PM »
I am new to robotics and am looking for some advice. What I want to do is make my robot follow a light source (like a flashlight). How would I go about doing this?
Offline newInRobotics
  • Helpful? 46
  • N.I.R.
Re: Following A Light
« Reply #1 on: July 30, 2012, 03:08:28 AM »
You probably want to read and complete (actually build) the famous $50 Robot tutorial :)
Offline greywanderer012345
« Reply #2 on: August 10, 2012, 04:20:38 PM »
When I made the $50 robot, I put the light sensors underneath the chassis so that it doesnt chase lights in the room. Instead, it chases light on the ground, like a flashlight. It works, but not great in a lit room. I think some photoresistors act differently for certain frequencies of light. Im thinking about looking into this to make a bot that follows a red laser specifically. Hope this helps.
« Reply #3 on: August 10, 2012, 11:06:26 PM »
Photoresistors (CdS) all have a fairly wide spectre and you won't get that much difference by changing them. If you add a color filter over any photoresistor, you can dampen its sensitivity to other colors, well enough to get it to differentiate eg. a red and a green LASER, but white light contains both red and green, so a filter letting eg. red through will also let the red part of white light through.
Pulsing the LASER will make it possible to exclude all other light - color won't.
« Reply #4 on: August 11, 2012, 10:13:46 PM »
Have you seen the "Follow Me Thomas" toy?
http://www.toysrus.com/product/index.jsp?productId=4048063
My niece got one of these, and it's the reason I wanted to try to get my bot to follow a laser. Instead of a laser(can't give those to 3 year olds) this toy comes with a red flashlight, and the train follows the circle where the beam is shone. I believe there is a sensor behind each bumper. I figured it used photo-resistors specific to red light. Do you think it just uses regular photo-resistors and covers them with transparent red plastic? The toy works very well, even following the light on red carpet or wooden floors and in brightly lit rooms.
« Reply #5 on: August 12, 2012, 04:06:29 PM »
All of this looks very interesting. I will certainly look into it. Thank you everyone for the input.
« Reply #6 on: August 19, 2012, 09:39:02 AM »
Now I have, thanks :)
Either color filters or they just use them plain. If there's a much larger amount of light where it shines, it doesn't need to be color sensitive. You could try with a bright white flashlight (it should work anyway, as there's red in the white) and with a green filter in front of the white flashlight - if green light doesn't work, it indicates red color filters. For testing, any piece of (resonably green) clear plastic should do.
Perhaps you can see it with your naked eye, as red filters would cover the distinct pattern of the CdS resistor.
To follow a LASER dot, you might wanna decollimate the LASER to a wider spot, to make it easier to follow.
Most pointers have a notch in the LASER head where a small coin or similar fits. If it's not sealed with glue or thread lock, it can be twisted/turned to collimate (parallelize the beam). When I use a pointer for such stuff, I usually make the spot as wide as around 5..10cm in diameter at a ~1m distance from the head.
Modulating the LASER beam and making the sensors ignore light from unmodulate sources will make it far better behaven.
To modulate it and keeping the switching speed resonably, set the low part to a point where it is just "lasing" (beyond that current, the light will just be like a weak red LED) and set the high part to te max. current it uses, with the voltage and internal resistance of the button cells it normally uses.
Offline arunyogesh46
« Reply #7 on: September 05, 2012, 09:33:14 AM »
I have a solution for all your doubts. It is very easy to make a light following robot without using microcontroller.
The step by step instructions to develop this robot is given in the below link. I made one from the details given in this website. It really works... try it... I hope you too will get the output...
http://www.roboticsbible.com/light-following-robot-without-using-microcontroller.html
Offline Adrianlstaton
« Reply #8 on: May 20, 2013, 01:35:44 PM »
Yea Its Really work. It is very Helpful for all of you. Try this.
Last post July 20, 2007, 07:08:51 PM
by megaman935
UV light
Started by Togo5 Misc
Last post June 26, 2007, 07:36:13 PM
by Tsukubadaisei
Last post June 22, 2009, 09:05:51 PM
by revhead
Last post April 09, 2013, 11:51:11 AM
by acoors
