Author Topic: A little help  (Read 465 times)
Offline ElimathewTopic starter
A little help
« on: August 10, 2012, 10:18:16 AM »
hey guys i building a basic line follower for this particular track
http://www.techfest.org/img/competitions/techolympics/gridmaster/zonal2_l.jpg
the robot should pass particular set of coordinates which is not fixed and is needed to be entered just before each run. i would appreciate some basic ideas regarding coding this robot .im using 8052 microcontroller keil compiler
« Last Edit: August 10, 2012, 10:25:55 AM by Elimathew »
Offline greywanderer012345
Re: A little help
« Reply #1 on: August 23, 2012, 07:45:34 AM »
What sensors are you able to use?
Do you have to use the method of inputting coordinates? I would approach it with turns, rather than coordinates.
//Pseudocode
If(Turn is Possible)
   turnDirection(turns[nextTurn++]);
Then, put 3 buttons for direction. For the example maze it would be turns[]={L,L,R,L,S,S,L,L}
