Author Topic: Dynamixel AX-12 Angle with WebbotLib  (Read 776 times)
Offline ErikYTopic starter
« on: August 16, 2012, 10:56:33 AM »
I got lucky and picked up a used Bioloid Premium humanoid on Craigslist for dirt cheap.
I am not overly interested in the robotis software, and really only wanted the servo's. Now I have 18 to play with.
I am going to breadboard the simple circuit tomorrow morning, and I was reading through the c++ documentation.
I don't see any way to specify an angle for these servo's, only speed.
So my assumption is if I don't set continuous rotation, setSpeed will go to an angle, and if I do set continuous rotation it will specify a speed.
I was under the impression you could control speed and angle with these servos.
Is there any way to do this in WebbotLib?
Offline Gertlex
  • Helpful? 23
  • Nuclear Engineer ˇ Roboticist
Re: Dynamixel AX-12 Angle with WebbotLib
« Reply #1 on: August 16, 2012, 12:14:41 PM »
It's a bit tricky. setSpeed actually does set the position when not in continuous rotation mode.  I think...
I don't actually use setSpeed; I forget exactly why (setSpeed might only do 256 positions, rather than the full 1024?). Instead I call
ax12SetGOAL_POSITION(&servo52, tilt_pos);
My messy but functional code using AX-12 servos + Axon can be found here https://github.com/erelson/Numa/blob/master/NumaWB2.c
I
« Reply #2 on: August 16, 2012, 01:30:44 PM »
Gertlex, thanks.
I tried that in c++ in a project I started in project designer and it is not working.
It is telling me:
DynamixelA12Test.cpp:36: error: cannot convert 'DynamixelAX12*' to 'const DYNAMIXEL_AX12*' for argument '1' to 'void ax12Write16(const DYNAMIXEL_AX12*, uint8_t, uint16_t)'
I tried a #define like you did, but that is causing errors as well, I think because project designer is already defining my servo1 for me.
Offline Gertlex
  • Helpful? 23
« Reply #3 on: August 16, 2012, 02:58:13 PM »
It should work in C++, but I've only done my work in C, so far (at one point I was using GaitDesigner, and when I tried going to C++, had compiling problems... so I stuck with C)
You'd have to post more code for me to diagnose what you're doing wrong. (Might be enough for Webbot though ;) )
I
Offline Webbot
  • Helpful? 107
« Reply #4 on: August 19, 2012, 07:13:19 AM »
To add the following C++ commands:-
void setClockwiseAngleLimit(uint16_t val);
void setCounterClockwiseAngleLimit(uint16_t val);
void setMaxTorque(uint16_t val);
void setGoalPosition(uint16_t val);
void setTorqueLimit(uint16_t val);
void setPunch(uint16_t val);
Replace the file
 Servos/Dynamixel/AX12.h
with the following code. You don't need to recompile WebbotLib.
 * $Id: AX12.h,v 1.3 2010/06/14 19:14:07 clivewebster Exp $
 * Revision History
 * $Log: AX12.h,v $
 * Revision 1.3  2010/06/14 19:14:07  clivewebster
 * Add copyright license info
 * Revision 1.2  2010/03/24 19:49:27  clivewebster
 * Alpha release
 * Revision 1.1  2010/03/08 17:05:57  clivewebster
 * *** empty log message ***
 * Copyright (C) 2010 Clive Webster ([email protected])
 *  This program is free software: you can redistribute it and/or modify
 *  it under the terms of the GNU General Public License as published by
 *  the Free Software Foundation, either version 3 of the License, or
 *  (at your option) any later version.
 *  This program is distributed in the hope that it will be useful,
 *  but WITHOUT ANY WARRANTY; without even the implied warranty of
 *  MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the
 *  GNU General Public License for more details.
 *  You should have received a copy of the GNU General Public License
 *  along with this program.  If not, see <http://www.gnu.org/licenses/>.
 * AX12.h
 *  Created on: 24 Feb 2010
 *      Author: Clive Webster
 *  Dynamixel AX-12 Servo
 *  See: http://www.trossenrobotics.com/dynamixel-ax-12-robot-actuator.aspx
 *  Voltage: 7v to 10v recommended=9.6
 *  Current: 50mA to 0.9Amps(max)
 *  *** This is not tested as I don't have one ****
#ifndef DYNAMIXEL_AX12_H_
#define DYNAMIXEL_AX12_H_
#include "../../actuators.h"
#include "../../_uart_common.h"
#include "../../iopin.h"
#ifdef __cplusplus
/* ===================== C Code ===============================================*/
extern "C" {
#endif
// Forward def
struct s_dynamixel_ax12_driver;
// The ID number to use in ax12Write when broadcasting a write to ALL servos.
#define ax12_BROADCAST_ID  0xfe
// Command values defined by the AX12 - so don't change!
#define ax12_WRITE 3 /* Write value */
#define ax12_READ  2 /* Read value */
#define ax12_REG_WRITE 4 /* Write value and wait for action*/
#define ax12_ACTION 5 /* process all REG_WRITE cmds */
// The data type used to return from ax12Info
typedef struct s_ax12_info {
DRIVE_SPEED speed; // current servo position/motor speed: DRIVE_SPEED_MIN to DRIVE_SPEED_MAX
int16_t   load; // Present load -0x3ff to +0x3ff
uint8_t voltage; // In tenths of a volt
uint8_t temperature; // In celsius
boolean batch; // Are we sending a command batch?
boolean moving; // Is the servo moving
int8_t rpm; // The current RPM: -114 to +114
} AX12_INFO;
// The infomation about one servo
typedef struct s_dynamixel_ax12 {
__ACTUATOR actuator; // has all the common stuff
struct s_dynamixel_ax12_driver* driver; // The driver it is attached to, set by init'ing the driver
uint8_t id; // unique Id 0-0xfd, 0xfe is reserved for broadcast
boolean continuous; // Is it a continuous rotation (ie a motor)
AX12_INFO info; // The current settings
} DYNAMIXEL_AX12;
// Define the standard constructor for a servo
#define MAKE_DYNAMIXEL_AX12(inverted, id, continuous)  { MAKE_ACTUATOR(inverted),null,id,continuous }
typedef DYNAMIXEL_AX12* /*PROGMEM*/  DYNAMIXEL_AX12_LIST;
typedef struct s_dynamixel_ax12_driver{
const DYNAMIXEL_AX12_LIST* const servos; // The servos
uint8_t num_servos; // The total number of servos
HW_UART*   ax12uart; // The hardware UART to use (must be h/w as baud=1,000,000
const IOPin* directionPin; // Pin for changing xmit/receive buffers
uint8_t writeCmd; // The current write command
} DYNAMIXEL_AX12_DRIVER;
#define MAKE_DYNAMIXEL_AX12_DRIVER(servolst, uart, dirpin) { \
servolst, \
(uint8_t)(sizeof(servolst)/sizeof(DYNAMIXEL_AX12*)), \
uart, \
dirpin, \
ax12_WRITE \
// Error return codes
#define AX12_RECV_LEN 0x1000 /* we received an invalid length */
#define AX12_RECV_ID 0x800 /* we received an invalid servo id */
#define AX12_RECV_HEADER 0x400 /* we received an invalid header */
#define AX12_RECV_CHECKSUM 0x200 /* we received an invalid checksum */
#define AX12_RECV_TIMEOUT 0x100 /* we timed out when receiving  */
#define AX12_ERROR_INSTRUCTION 0x40 /* undefined instruction */
#define AX12_ERROR_OVERLOAD 0x20    /* the maximum torque cannot drive the load */
#define AX12_ERROR_CHECKSUM 0x10 /* we sent the wrong checksum to the AX12 */
#define AX12_ERROR_RANGE 0x8 /* the instruction range was invalid */
#define AX12_ERROR_OVERHEAT 0x4 /* the servo is overheating */
#define AX12_ERROR_ANGLE 0x2 /* the angle is out of range */
#define AX12_ERROR_VOLTAGE 0x1 /* the voltage is out of range */
// Define memory locations
// Single byte
#define ax12_ID 3
#define ax12_BAUD 4
#define ax12_RETURN_DELAY 5
#define ax12_TEMPERATURE_HIGH 11
#define ax12_VOLTAGE_LOW 12
#define ax12_VOLTAGE_HIGH 13
#define ax12_STATUS_RTN_LEVEL 16
#define ax12_ALARM_LED 17
#define ax12_ALARM_SHUTDOWN 18
#define ax12_TORQUE_ENABLE 24
#define ax12_LED 25
#define ax12_CW_COMPLIANCE_MARGIN 26
#define ax12_CCW_COMPLIANCE_MARGIN 27
#define ax12_CW_COMPLIANCE_SLOPE 28
#define ax12_CCW_COMPLIANCE_SLOPE 29
#define ax12_REGISTERED_INST 44
#define ax12_LOCK 47
// Double byte
#define ax12_CW_ANGLE_LIMIT 6
#define ax12_CCW_ANGLE_LIMIT 8
#define ax12_MAX_TORQUE 14
#define ax12_GOAL_POSITION 30
#define ax12_MOVING_SPEED 32
#define ax12_TORQUE_LIMIT 34
#define ax12_PUNCH 48
// Read only
#define ax12_PRESENT_POSITION 36
#define ax12_PRESENT_SPEED 38
#define ax12_PRESENT_LOAD 40
#define ax12_PRESENT_VOLTAGE 42 /* 8 bit */
#define ax12_PRESENT_TEMPERATURE 43 /* 8 bit */
#define ax12_MOVING 46 /* 8 bit */
// Single byte  commands
#define ax12SetID(servo,val) ax12Write8(servo,ax12_ID, CLAMP(val, 0,253))
#define ax12SetBAUD(servo,val)   ax12Write8(servo,ax12_BAUD, CLAMP(val, 0,254))
#define ax12SetRETURN_DELAY(servo,val)   ax12Write8(servo,ax12_RETURN_DELAY, CLAMP(val, 0,254))
#define ax12SetTEMPERATURE_HIGH(servo,val)   ax12Write8(servo,ax12_TEMPERATURE_HIGH, CLAMP(val, 0,150)) /* celsius */
#define ax12SetVOLTAGE_LOW(servo,val) ax12Write8(servo,ax12_VOLTAGE_LOW, CLAMP(val,50,250)) /* tenths of a volt */
#define ax12SetVOLTAGE_HIGH(servo,val)   ax12Write8(servo,ax12_VOLTAGE_HIGH, CLAMP(val,50,250)) /* tenths of a volt */
#define ax12SetSTATUS_RTN_LEVEL(servo,val)   ax12Write8(servo,ax12_STATUS_RTN_LEVEL, CLAMP(val, 0,  2))
#define ax12SetALARM_LED(servo,val)   ax12Write8(servo,ax12_ALARM_LED, CLAMP(val, 0,127))
#define ax12SetALARM_SHUTDOWN(servo,val) ax12Write8(servo,ax12_ALARM_SHUTDOWN, CLAMP(val, 0,127))
#define ax12SetTORQUE_ENABLE(servo,val)   ax12Write8(servo,ax12_TORQUE_ENABLE, CLAMP(val, 0,  1))
#define ax12SetLED(servo,val)   ax12Write8(servo,ax12_LED, CLAMP(val, 0,  1))
#define ax12SetCW_COMPLIANCE_MARGIN(servo,val)  ax12Write8(servo,ax12_CW_COMPLIANCE_MARGIN, CLAMP(val, 0,254))
#define ax12SetCCW_COMPLIANCE_MARGIN(servo,val) ax12Write8(servo,ax12_CCW_COMPLIANCE_MARGIN, CLAMP(val, 0,254))
#define ax12SetCW_COMPLIANCE_SLOPE(servo,val)   ax12Write8(servo,ax12_CW_COMPLIANCE_SLOPE, CLAMP(val, 0,254))
#define ax12SetCCW_COMPLIANCE_SLOPE(servo,val)  ax12Write8(servo,ax12_CCW_COMPLIANCE_SLOPE, CLAMP(val, 0,254))
#define ax12SetREGISTERED_INST(servo,val)    ax12Write8(servo,ax12_REGISTERED_INST, CLAMP(val, 0,  1))
#define ax12SetLOCK(servo)      ax12Write8(servo,ax12_LOCK, 1)
// Double byte  commands
#define ax12SetCW_ANGLE_LIMIT(servo,val) ax12Write16(servo,ax12_CW_ANGLE_LIMIT,CLAMP(val,0,1023))
#define ax12SetCCW_ANGLE_LIMIT(servo,val) ax12Write16(servo,ax12_CCW_ANGLE_LIMIT,CLAMP(val,0,1023))
#define ax12SetMAX_TORQUE(servo,val) ax12Write16(servo,ax12_MAX_TORQUE,CLAMP(val,0,1023))
#define ax12SetGOAL_POSITION(servo,val) ax12Write16(servo,ax12_GOAL_POSITION,CLAMP(val,0,1023))
#define ax12SetMOVING_SPEED(servo,val) ax12Write16(servo,ax12_MOVING_SPEED,CLAMP(val,0,0x7ff))
#define ax12SetTORQUE_LIMIT(servo,val) ax12Write16(servo,ax12_TORQUE_LIMIT,CLAMP(val,0,1023))
#define ax12SetPUNCH(servo,val) ax12Write16(servo,ax12_PUNCH,CLAMP(val,0,1023))
// Servo specific commands
void ax12Write8(const DYNAMIXEL_AX12* servo, uint8_t cmd, uint8_t data); // Write a single byte variable
void ax12Write16(const DYNAMIXEL_AX12* servo, uint8_t cmd, uint16_t data); // Write a double byte variable
uint16_t ax12GetInfo(DYNAMIXEL_AX12* servo); // Get latest info
void ax12Dump(DYNAMIXEL_AX12* servo); // calls ax12GetInfo for 1 servo and dumps to rprintf
void ax12DumpTo(FILE* f,DYNAMIXEL_AX12* servo); // calls ax12GetInfo for 1 servo and dumps to rprintf
// Driver, ie multi servo, commands
void ax12Init(DYNAMIXEL_AX12_DRIVER* driver, BAUD_RATE baud); // Initialise to a given baud rate
void ax12Send(const DYNAMIXEL_AX12_DRIVER* driver, uint8_t id, size_t len, uint8_t* data); // Send a sequence of bytes starting with 0xff,0xff and ending in checksum
void ax12DumpAll(const DYNAMIXEL_AX12_DRIVER* driver); // calls ax12GetInfo for all servos and dumps to stdout
void ax12DumpAllTo(FILE* f,const DYNAMIXEL_AX12_DRIVER* driver); // calls ax12GetInfo for all servos and dumps to file
void ax12Begin(DYNAMIXEL_AX12_DRIVER* driver); // all cmds are queued until ax12End
void ax12End(DYNAMIXEL_AX12_DRIVER* driver); // perform cmds issued since the ax12Begin
#ifdef __cplusplus
class DynamixelAX12 : public Actuator{
public:
DynamixelAX12(DYNAMIXEL_AX12* c) : Actuator(&c->actuator){
m_ax12 = c;
uint8_t getID(void) const{
return m_ax12->id;
uint16_t read(void){
return ax12GetInfo(m_ax12);
// Get the actual speed/position of the servo
DRIVE_SPEED getActualSpeed(void) const{
return m_ax12->info.speed;
// Get the current rotational speed  -114 rpm  to +114 rpm
int8_t getActualRPM(void) const{
return m_ax12->info.rpm;
// Get the current load -0x3ff to +0x3ff
int16_t getActualLoad(void) const{
return m_ax12->info.load;
uint8_t getActualVoltage(void) const{
return m_ax12->info.voltage;
// Get temperature in celsius
uint8_t getActualTemperature(void) const{
return m_ax12->info.temperature;
// Is the servo moving?
boolean getActualIsMoving(void) const{
return m_ax12->info.moving;
void dump(FILE* f = stdout){
return ax12DumpTo(f, m_ax12);
void ledOn(void) const{
ax12Write8(m_ax12,ax12_LED, 1);
void ledOff(void) const{
ax12Write8(m_ax12,ax12_LED, 0);
void setClockwiseAngleLimit(uint16_t val){
if(val>1023) val = 1023;
ax12Write16(m_ax12,ax12_CW_ANGLE_LIMIT,val);
void setCounterClockwiseAngleLimit(uint16_t val){
ax12Write16(m_ax12,ax12_CCW_ANGLE_LIMIT,val);
void setMaxTorque(uint16_t val){
ax12Write16(m_ax12,ax12_MAX_TORQUE,val);
void setGoalPosition(uint16_t val){
ax12Write16(m_ax12,ax12_GOAL_POSITION,val);
if(val>0x7ff) val = 0x7ff;
ax12Write16(m_ax12,ax12_MOVING_SPEED,val);
void setTorqueLimit(uint16_t val){
ax12Write16(m_ax12,ax12_TORQUE_LIMIT,val);
void setPunch(uint16_t val){
ax12Write16(m_ax12,ax12_PUNCH,val);
protected:
void write8(uint8_t cmd, uint8_t data) const{
ax12Write8(m_ax12,cmd,data);
void write16(uint8_t cmd, uint16_t data) const{
ax12Write16(m_ax12,cmd,data);
private:
DYNAMIXEL_AX12* m_ax12;
class DynamixelAX12Driver{
public:
DynamixelAX12Driver(DYNAMIXEL_AX12_DRIVER* cstr){
driver = cstr;
void dumpAll(FILE* f = stdout) const{
ax12DumpAllTo(f, driver);
void begin(void) const{
ax12Begin(driver);
void end(void) const{
ax12End(driver);
void send(uint8_t id, size_t len, uint8_t* data){
ax12Send(driver, id, len, data);
private:
DYNAMIXEL_AX12_DRIVER* driver;
#endif
#endif /* DYNAMIXEL_AX12_H_ */
Offline Gertlex
  • Helpful? 23
« Reply #5 on: August 19, 2012, 09:16:58 AM »
Webbot, you define setGoalPosition twice. I think the second one was meant to be setMovingSpeed()?
I
Offline Webbot
  • Helpful? 107
« Reply #6 on: August 19, 2012, 09:54:47 AM »
Thanks Gertlex for spotting my deliberate mistake  ;D.
The new/missing command is:
void setMovingSpeed(uint16_t val);
The file should be:
 * Revision History
 * $Log: AX12.h,v $
 * Alpha release
 * AX12.h
#ifdef __cplusplus
extern "C" {
#endif
// Forward def
} AX12_INFO;
} DYNAMIXEL_AX12;
servolst, \
uart, \
dirpin, \
ax12_WRITE \
// Single byte
#define ax12_ID 3
#define ax12_BAUD 4
#define ax12_LED 25
// Double byte
// Read only
#ifdef __cplusplus
public:
m_ax12 = c;
return m_ax12->id;
void setMovingSpeed(uint16_t val){
protected:
private:
public:
driver = cstr;
ax12Begin(driver);
ax12End(driver);
private:
#endif
« Reply #7 on: August 20, 2012, 08:21:07 AM »
Webbot,
Thanks. I was able to get the setGoalPosition method working.
I appreciate the code!
Gertlex, thanks for your help as well.
I am going to play with these dynamixels some more.
These things are very cool.
Webbot, if I have hardware UART on my board, and I do a dump from the dynamixal library, will it print out or do I need to use a PRINTF or other print command?
I have been trying to print out the dumpAll or the dump functions using:
myUart.print(ax12_driver1.dumpAll());
And I get an invalid use of void expression which I do not quite understand.
Thanks!
« Last Edit: August 20, 2012, 01:37:21 PM by ErikY »
Offline Webbot
  • Helpful? 107
« Reply #8 on: August 20, 2012, 03:47:35 PM »
Assuming you are still using C++ then just call the dumpAll() method on the driver. ie probably something like:
ax12_driver1.dumpAll();
I say 'probably' as it depends on what name you've given the driver in Project Designer.
Output will go to wherever you set the stdout to in the CodeGen from Project Designer.
Absolutely! If I had the money I would never buy any other sort of servo!
Last post April 06, 2009, 07:04:46 PM
by Webbot
Last post February 22, 2010, 06:01:08 AM
by HDA
Last post July 26, 2012, 12:02:58 PM
by Webbot
Last post June 06, 2012, 09:32:38 AM
by Gertlex
