Author Topic: linking 30 actuators to an ooPIC  (Read 1517 times)
Offline NestorClassFourTopic starter
« on: July 20, 2007, 08:56:22 AM »
REALLY IMPORTANT!!! Can someone please tell me how to link the on-board computer (ooPic) with my actuators. The real problem is I have over 30 actuators! HELP!
"I see the logic of your plan, it just seems too.....heartless," (Sonny, I robot, 2004)
admin edit: I changed your subject 'URGENT! I can't get the damn microcontroller to work!' to something more useful.
« Last Edit: July 22, 2007, 11:46:21 AM by Admin »
Offline hazzer123
Re: URGENT! I can't get the damn microcontroller to work!
« Reply #1 on: July 20, 2007, 11:03:33 AM »
Please read this http://www.societyofrobots.com/robotforum/index.php?topic=1480.0
Some examples of what you didnt tell us -
what actuator?
Your code so far
Your application
www.icrobotics.co.uk
« Reply #2 on: July 22, 2007, 11:45:16 AM »
Its going to be really hard to do this. You will need to use a controller that can do I2C daisy chaining (Ive never done this, so cant really help you here).
99% of all microcontrollers dont have more than about 25 digital outputs, so you may need to cut down on your actuators. Or use multiple microcontrollers.
Offline Ro-Bot-X
  • Helpful? 25
  • Store: RoBotXDesigns.ca
Re: linking 30 actuators to an ooPIC
« Reply #3 on: July 22, 2007, 01:03:05 PM »
ooPic microcontroller uses objects and each object uses a few bytes of object data. For example, a oServo object uses 4 bytes and a oServoX uses 6 bytes. The total amount of object memory is 86 bytes. So, if you are using 30 servos you will need 120 bytes of object memory, a lot more than one ooPic offers. I would sugest the use of 2 ooPic-R boards linked by I2C. These boards have 16 I/O lines factory built for servo use.
Last post August 08, 2006, 04:21:59 AM
by dunk
Last post July 13, 2008, 11:04:58 AM
by izua
Last post January 22, 2011, 11:35:54 PM
by acornstu
Last post October 03, 2011, 05:20:51 PM
