Author Topic: Choosing the right diode for the situation  (Read 517 times)
« on: August 19, 2012, 01:39:35 PM »
Hey guys I have this motor I want to use for my arduino but I don't want to destroy my arduino because of the reverse voltage the motor will produce
so how do I choose the right diode for the situation and  How exactly would I calculate this?
just in case your wonder where i got this motor from
 -I got the motor from the rc car that tonka made but its fairly old
 -I tried to see if i could reuse any diodes in the circuit but I couldn't find any anywhere
 -the car runs on 4 double AA batteries
Re: Choosing the right diode for the situation
« Reply #1 on: August 19, 2012, 03:53:31 PM »
You're not trying to conect a motor directly to an I/O pin on the Arduino I hope?
Diodes are not calculated, but chosen for the pararmeters you have.
We could try to calculate how fast you'd ruin your Arduino if you connect it directly, but it'd probably be less than 1ms, so do we bother  ;)
You need a motor driver in-between and that is what you protect with diodes.
To find out what power handling is needed from the driver, you need to measure your motor.
« Reply #2 on: August 19, 2012, 05:17:37 PM »
but why not,
what's wrong with connecting the motor directly to the arduino (with diodes)?
and what does the motor controller do exactly(how does it generally works?
« Reply #3 on: August 19, 2012, 05:19:10 PM »
sorry not motor controller but motor driver(is there a difference?)
« Reply #4 on: August 19, 2012, 07:27:05 PM »
but why not,
You destroy the microcontroller in the Arduino, either fully or "just" one (or more) I/O pins.
It takes a low current in and gives a higher current out.
A motor driver is just a current amplifier, while a motor controller implies that there's some kind of logic circuitry (perhaps a microcontroller) involved, but sometimes they get mixed up.
Please use "Modify" rather than serial posting!
And please start reading some basic electronics tutorials (Google is your friend) - you'd be able to answer most of your questions here yourself with just a little bit of reading.
Offline jkerns
  • Helpful? 10
« Reply #5 on: August 20, 2012, 07:10:19 AM »
Read the specifications on your Arduino - pay particularly close attention to how much current the I/O pins can handle. Compare that to how much current you motor will be using. You can't put 0.5  pounds in a bag that only holds 0.02 pounds.
Last post December 26, 2008, 09:15:55 PM
by dsesmg
Last post January 31, 2011, 01:59:21 PM
Last post January 15, 2012, 10:35:37 AM
by gerard
Last post October 19, 2012, 04:50:44 AM
by Razor Concepts
