Author Topic: Selecting proper motor!  (Read 538 times)
Offline saba_rish91Topic starter
« on: August 22, 2012, 11:23:32 AM »
I'm planning to build a line following robot and I'm unable to decide a proper motor for that purpose.
In the motor spec, it says 0.6kg-cm. What does that imply? Does it mean that it can comfortably push 600gms if the motor is attached to a 1cm radius wheel?
http://www.pololu.com/catalog/product/2212
Strike when the iron is hot!
Offline jkerns
  • Helpful? 10
Re: Selecting proper motor!
« Reply #1 on: August 22, 2012, 12:32:18 PM »
Not quite that simple - yes you generate a 600 "gram" force, but a wheeled robot on a horizontal surface that weighs 600 grams does not need that much force to move.
Also, that appears to be the stall torque - the torque generated when the motor is not turning. As the motor speeds up, the torque is reduced.
http://www.societyofrobots.com/mechanics_dynamics.shtml
There is a link to a motor calculator there as well.
http://www.ltu.edu/engineering/mechanical/robotics_engineering.asp
Last post February 07, 2009, 07:25:28 AM
Last post December 25, 2010, 08:44:48 AM
by ratulxy
Last post January 06, 2011, 12:38:11 AM
by anir_yogi
Last post February 20, 2013, 01:18:29 AM
by newInRobotics
