Author Topic: can bluetooth connect arduino?  (Read 575 times)
Offline ironheartbj18Topic starter
« on: August 26, 2012, 10:31:55 PM »
i check out myself on Amazon bluetooth module serial adapter the link is http://www.amazon.com/Banggood-Wireless-Bluetooth-Transceiver-Backplane/dp/B008MVIBV4/ref=wl_it_dp_o_pC_nS_nC?ie=UTF8&colid=3LTHHNKZZI3WX&coliid=IX579Q1OUOWH6. Will it work with Arduino? If so, Where the bluetooth four wires connect to Arduino pins?
can you make an example schemath please do i will apprentice your answer thanks!
Re: can bluetooth connect arduino?
« Reply #1 on: August 27, 2012, 04:35:56 AM »
[...] Will it work with Arduino? If so, Where the bluetooth four wires connect to Arduino pins?
It will work with anything that has got a serial port.
The four pins has to be Gnd, +5V, TX and RX, but probably not in that particular order - the module will either have it written or some documentation to tell which is which.
Check your documentation for how to set up a serial port and which pins are used.
Come on, it's 4 wires - I'd appreciate if you don't expect to be spoonfed. If you're not up to that, you better leave the module alone for now.
« Reply #2 on: September 02, 2012, 02:01:54 AM »
i followed everything on the schematic what they said on youtube the link is
Experiencia Arduino + Bluetooth + Android - parte 2/3
( i am not sure if they speak Spanish language since i am proud to be Deaf)
my Android were working connected to Bluetooth. i can see the blink different from Bluetooth serial module.
why did i get this on my Arduino after upload by said "avrdude: stk500_getsync(): not in sync: resp=0x00"???
any body knowledge about this to solution the problem????
Last post September 22, 2012, 06:40:19 AM
by streamlinedwings
Last post September 19, 2008, 08:28:09 AM
Last post August 19, 2010, 07:27:51 PM
by Joker94
Last post September 08, 2010, 11:22:46 AM
by Ji Jing Meng
