Author Topic: Help with board choice for 3d mapping application  (Read 342 times)
Offline rdcmmnstTopic starter
« on: August 27, 2012, 11:22:46 AM »
X
« Last Edit: August 29, 2012, 01:58:35 PM by rdcmmnst »
Re: Help with board choice for 3d mapping application
« Reply #1 on: August 27, 2012, 01:08:48 PM »
[...] The fastest travel speed is approximately 60 ft/min, which translates to a minimum of 100 Hz sampling rate (for the .125" accuracy) and the longest run will be 2,500 ft.
100Hz leaves you plenty of time!
Even a very cheap microcontroller is able to do 1MIPS, so in the 10ms you have per sample, there's room for at least 10'000 instructions.
My question is what micro controller/programming environment is going to he hefty enough to handle task but user friendly enough for novice programmers to develop this tool in a years time.
You really dont need hefty, but rather user friendly, easy to learn and with a large user base, making it easy to get help and code snippets.
I'd recommend an Arduino for its huge support by other users and if you feel a need for more horsepower, one of the 80MHz PIC based chipKIT's which are code- and interface compatible with Arduinos (Like an Arduino on steroids).
I was looking at this board for the gyro as it already has a kalman filter built in and seems to be rather user friendly.
This board alone could do what you want, by interfacing the encoder to it, but I have my doubt about its beginner friendliness. It might be worth a try though, if you're going to buy it anyway.
Alternatively, you could get the "raw" sensors - and probably save a bunch.
Would we be able to pair this with an encoder?
Yes.
Do you have a particular encoder in mind or...?
Getting an encoder with SPI or IIC interface would be a good idea if you want to interface it to the board directly.
« Reply #2 on: August 27, 2012, 10:43:16 PM »
X
« Last Edit: August 29, 2012, 01:59:47 PM by rdcmmnst »
Last post February 07, 2009, 11:16:41 AM
by BANE
Last post October 16, 2009, 09:42:10 AM
by waltr
Last post February 23, 2011, 06:43:00 PM
by newInRobotics
Last post October 06, 2011, 10:13:07 PM
by rahulver
