Author Topic: How to connect this motor  (Read 609 times)
Offline bobthefirst1Topic starter
« on: September 16, 2012, 10:19:47 AM »
I need ideas on how to attach this motor to spin a pipe. Look at the picture
Offline Billy
Re: How to connect this motor
« Reply #1 on: September 17, 2012, 02:18:58 PM »
use epoxy to glue the motor shaft into the hole on the pipe.
A better answer will require a better question. Look at your question.
Offline misrobot
  • Just a old schooled Biker and Technician
« Reply #2 on: October 12, 2012, 02:37:41 PM »
How about using a rubber sleeve on the motor shaft to drive yout pipe in either direction
you can use  a motor base fulcrum  with a spring to keep constant drive pressure
Because I use a wheelchair  I am alway's thinking on motion / leverage with least resistance .
Last post September 04, 2008, 07:02:21 PM
Last post October 06, 2009, 04:52:41 PM
Last post May 16, 2010, 10:15:05 PM
by Razor Concepts
Last post October 18, 2011, 01:35:11 PM
by newInRobotics
