Author Topic: gripper cliamp needed  (Read 1823 times)
Offline dmehlingTopic starter
« on: July 22, 2007, 02:56:00 PM »
I need to implement a robotic gripper design for my project.  I would like one that functions more like a clamping mechanism in which the upper and lower "fingers" move toward each other in a linear direction as opposed to gripper fingers that rotate inward in a circular manner.  I need it to open at least 3 inches, and it needs to be not very expensive since I need three of these grippers.  Does such a product exists.  If not, I'll need to design my own and would need to know what kind of actuator to use: rack and pinion, screwdriver, or linear stepper motor?
Offline Brandon121233
Re: gripper cliamp needed
« Reply #1 on: July 22, 2007, 07:44:17 PM »
Could you give me an idea of how much gripping force you need, or how heavy the stuff is you plan on gripping?
        —Thomas Edison
Offline Ro-Bot-X
  • Helpful? 25
  • Store: RoBotXDesigns.ca
« Reply #2 on: July 23, 2007, 03:19:04 AM »
Offline Steve Joblin
« Reply #3 on: July 23, 2007, 01:42:15 PM »
Offline thomasrex
« Reply #4 on: July 25, 2007, 11:42:49 AM »
The problem with the Boebot design (which uses a set of struts that form a parallelogram, thus always keeping the ends paralell) is that is still moves the tips of the gripper OUT as it clamps.
That was unacceptable for a gripper I built, so eventually I  found a linear roller slide track, combined with a screw thread or acme screw, did the trick.  Attach your gripper to the slider, move it with the screw thread or acme screw, turned by a servo or stepper motor.
Got a 4" grip, perfectly linear clamping action.
Have fun!
Last post August 18, 2008, 05:32:40 AM
by airman00
Last post December 01, 2009, 03:13:43 PM
by borg
Last post January 23, 2010, 04:27:14 PM
by nottoooily
Last post February 05, 2010, 04:15:44 PM
by little-c
