Author Topic: Choosing motors for an arduino robot to compete in robocup jnr  (Read 451 times)
Offline keyboard1333Topic starter
« on: October 03, 2012, 06:52:25 PM »
Hey Guys!
Me and a friend recently started plans to build a robot using an Arduino Uno to compete in the Australian Robocup Junior Soccer competion.
A friend who has competed in previous years, used 200rpm 12v 1.2A motors.
Do you think that that is enough power to move a robot weighing a couple of kilos rather quickly?
(Like half a meter a second)
If not, what are the specs for the kind of motor that we want?
Thanks, keyboard1333
Offline newInRobotics
  • Helpful? 45
  • N.I.R.
Re: Choosing motors for an arduino robot to compete in robocup jnr
« Reply #1 on: October 04, 2012, 03:03:34 AM »
You didn't mention wheel diameter  :)
« Reply #2 on: October 04, 2012, 04:07:01 AM »
Between 1 & 2 inches.
  • Helpful? 45
  • N.I.R.
« Reply #3 on: October 04, 2012, 06:06:52 AM »
Then max velocity achievable (without taking friction into consideration) will be between ~0.27 m/s to ~0.53 m/s. It's clear that 1" wheels don't really cut it, hence let's go with 2" wheels.
  • Circumference = Diameter * pi
  • Velocity = Circumference * RPM
To have acceleration of 0.25 m/s2 (to be able to reach 0.5 m/s velocity in 2 seconds) each motor has to be capable of at least 63.5 mN*m torque.
  • Force = Mass * Acceleration
  • Torque = Radius * Force
You probably don't want to run motors at 100% duty cycle all the time, so to be on a safe side lets say that You want to achieve aforementioned results while running motors at 75% duty cycle. So, max motor RPM has to be at least ~252 RPM and stall torque has to be at least ~85 mN*m.
For what You want, something like 300 RPM 12V 0.39 N*m motor would be more that enough. Of course if plan on using 12V. What voltage are You planning to use?
« Last Edit: October 04, 2012, 08:01:31 AM by newInRobotics »
Last post December 30, 2010, 04:36:45 PM
by pmckinnon
Last post March 25, 2011, 07:57:52 AM
by waltr
Last post May 06, 2012, 09:42:07 PM
by Gertlex
Last post October 29, 2012, 10:16:39 PM
by stridera
