Author Topic: two devices with one UART?  (Read 2500 times)
Offline AdminTopic starter
« on: July 23, 2007, 06:26:48 PM »
I want to control both my CMUcam and have a bluetooth connection simultaneously with my ATmega168. Since they both require UART, is this possible?
My guess is that the CMUcam will ignore incorrect commands, and on the bluetooth side I can ignore any data that is CMUcam commands. But not really sure . . .
Or am I being noob like?
Offline hgordon
  • Helpful? 7
Re: two devices with one UART?
« Reply #1 on: July 23, 2007, 08:56:45 PM »
I know the feeling of not having enough serial ports, but it's unlikely that the attached devices would handle the confusion, not to mention issues of different devices pulling the signal lines in opposite directions at the same time.  The only thing you might consider is to add a set of digital switches that route the UART lines between devices under software control.
Surveyor Corporation
  www.surveyor.com
« Reply #2 on: July 24, 2007, 05:44:00 AM »
Good idea!
Hmmm the best way I can think of doing this is with 4 mosfets (one for each tx and rx line), an inverter, and one digital I/O line. Is there a better way to do this? I feel as if there might be an IC out there already for this . . .
Offline Hal9000
« Reply #3 on: July 24, 2007, 06:13:30 AM »
I've been doing DSP, but on the maths and not the practicalities!
Aren't you looking for a multiplexer or sorts?
Offline JonHylands
« Reply #4 on: July 24, 2007, 06:22:24 AM »
Admin,
Check out the ATmega162 - its a DIP 40, but its got two hardware UARTs.
- Jon
Offline dunk
« Reply #5 on: July 24, 2007, 06:36:27 AM »
yup. there's quite a few AVRs out there with multiple UARTs.
alternatively you could use one hardware UART and bit bang a 2nd.
Offline hgordon
  • Helpful? 7
« Reply #6 on: July 24, 2007, 09:28:03 AM »
Bit banging is a good idea - leave the bluetooth on the UART, since it will be receiving asynchronous requests from the host, while the CMUcam is always under processor control, so you won't lose any data when not watching that software port.
  www.surveyor.com
Last post December 06, 2010, 06:35:36 PM
Last post April 23, 2009, 03:17:17 PM
by TrickyNekro
Last post May 23, 2012, 11:49:06 AM
by aaa3a
Last post May 27, 2012, 11:31:49 AM
by Webbot
