Author Topic: IR range sensor help  (Read 429 times)
Offline ChocotwilightTopic starter
« on: October 11, 2012, 11:36:47 PM »
Hi! I'm working on a lego meteorite harvester project and i'm a little confused about the IR range sensor. I attached it to the servo to get a constant scanning of area but i have no idea how to code it. After it scanned, what do i need to make it in when it detected an array of values?
#void main()
    while(!start_button());
    while(1)
        int array[15];
        int i;
        printf("Testing IR range value! \n");
        for(i=0;i<15;i++)
            array= analog(5);
            printf("value =%d\n",array);
        while((!start_button())&&(!stop_button()));
        if(stop_button()) break;
this is the code i make to see the value it gets.
#void main()
      printf("Bumper test!!\n");
    while(1)
        check_distance();
void check_distance()
    int irval = analog(IRFinder);
    //If there is wall, value approx.50-110
    //if there isn't wall, value approx 0
    if(irval> 50) //to be set later
        go_straight();
    else
        go_back();
        msleep(1000L);
        turn_around();
this is the command i make whether it detects something or not.I know i am suppose to get something like "0 0 0 0 1 1 1 1 0 0 0 0" if there is something infront. if i know there's something in between, how do i make it go that direction?
I have no idea what to do with it, it would be great if someone here can help me with it! =)
Last post March 15, 2009, 03:03:40 PM
by Trumpkin
Last post March 09, 2010, 10:40:22 PM
by logicguy
Last post August 20, 2010, 06:06:11 AM
Last post May 02, 2013, 08:52:15 PM
by jwatte
