Author Topic: Novice Question on Robot Sensoring  (Read 266 times)
Offline TomtheTATopic starter
« on: October 19, 2012, 03:52:32 PM »
Hello, first time robot builder here.
I want a robot that can follow a human. Right now I am planning to use an ultrasonic transmitter that will go on the user's belt. Two more transmitters will be on the robot. The robot's transmitters will send a signal to the user. The user will send a signal back giving the distance between them. Using this, I want to calculate the user's distance (obviously), speed, and acceleration. Is this a viable strategy for robot distance sensoring? In my research there seems to be a lot of different approaches, without one being the clearly superior choice.
Thank you.
Re: Novice Question on Robot Sensoring
« Reply #1 on: October 19, 2012, 05:32:01 PM »
hI,
[...] The robot's transmitters will send a signal to the user. The user will send a signal back giving the distance between them.
How do you plan to calculate the distance from that?
Your first problem is to get reliable distance data, which I can't imagine how you hope to get from the above description and for speed and acceleration, you need more than just the distance between human and robot (and time), as you'd only get relative distance/speed/etc, without an absolute reference.
Last post May 13, 2009, 07:16:33 AM
by Chris_Balls
Last post October 13, 2009, 07:22:31 PM
by Ryan the Robot Novice
Last post December 12, 2011, 01:08:43 PM
by john145
Last post October 13, 2012, 05:33:48 AM
by mike_522
