Noob question, gears, shafts, and attachments
(1/1)
CRich:
Hi guys,
I have a small problem...
I want to use a vex mulit-dir wheel, which takes a square shaft, but my servo has a spline.
is there a product to bridge my gap or do i need to run them gear to gear (gear on servo and gear on wheel)?
Also, does anyone know a good company to purchase bevel or miter gears from?
Razor Concepts:
Ideally you would use VEX servos which have a square hole instead of a standard servo spline
Soeren:
--- Quote from: CRich on October 28, 2012, 03:22:33 PM ---I want to use a vex mulit-dir wheel, which takes a square shaft, but my servo has a spline.
--- End quote ---
You didn't mention the make of your servo (splines differ from one make to another), but here's a hub for Hitec servos that should be modifiable if you're handy:
http://www.active-robots.com/motors-wheels/hubs/servo-horn-tubing-adapter-pair.html
They'll cost you around half of a Vex motor though.
Navigation
