Author Topic: Motor for QuadCopter  (Read 1155 times)
Offline vipulan12Topic starter
« on: October 30, 2012, 08:08:41 PM »
Hey, I am currently looking for motors useful for quad copters
-the motors needs to have high RPM, adequate torque and be extremely light weight
-the quad copter is expected to lift a camera
currently the weight of camera and other parts are unknown
I am planning to use my arduino uno for this project
any suggestions or advice would be helpful
Re: Motor for QuadCopter
« Reply #1 on: October 31, 2012, 04:14:42 PM »
Errr... Finding the total weight is not just a good idea - it's mandatory!
You can't find the needed motor/propellor combination without knowing how much weight it have to lift.
« Reply #2 on: November 04, 2012, 10:05:16 PM »
so lets say i have the the weight,How would i calculate it,What formula would you use?
Offline jkerns
  • Helpful? 10
« Reply #3 on: November 05, 2012, 08:24:58 AM »
Obviously, the total available thrust will have to exceed the total weight, right? And you need some margin to allow some motors to be throttled back to make it turn / move.
A quick google search for "brushless DC motor propeller thrust" turns up quite a few resources such as http://adamone.rchomepage.com/guide5.htm
Of course, you have the old chicken and egg problem - you don't know how much it will weigh until you pick the motors and the batteries. But you don't know what motor / batteries to pick until you know the weight. Right?  So you guess. Pick a weight, see what motors that leads you to, check to see if you are close to your target weight, then guess again. After a few tries, you should get a workable answer.
http://www.ltu.edu/engineering/mechanical/robotics_engineering.asp
« Reply #4 on: November 18, 2012, 06:36:39 PM »
what is the formula to calculate lift for a quadcopter?
  • Helpful? 84
« Reply #5 on: November 18, 2012, 07:43:07 PM »
Did you google "propeller thrust"?
Lot and lots if info from simple calulators to complete equations on the design of propellers for quad copters.
« Reply #6 on: November 19, 2012, 02:55:00 PM »
i did but i dont know where to start
most of these calculators are complicated and have all kinds of features
  • Helpful? 84
« Reply #7 on: November 19, 2012, 03:44:30 PM »
Exactly.
The solution is not a simple one and is the reason I said to google and read. As with any learning you need to spend time studing.
The simplest solution is to use the exact motor-propeller combination someone else has used to successfully build a quadcopter.
« Reply #8 on: November 19, 2012, 05:59:45 PM »
alright thanks
Last post September 28, 2007, 01:07:34 PM
by h3ro
Last post October 19, 2009, 05:02:32 AM
by Joker94
Last post June 01, 2010, 04:32:51 AM
by innerbreed
Last post May 09, 2011, 11:44:54 AM
by Canabots
